Skip to product information
1 of 4
Triumph Daytona, Street Triple, Speed Triple AiM Solo 2 DL Plug & Play Lap Timer Kit
SKU: SOLO2-K-TRI
€774,95 EUR
€774,95 EUR
AiM Solo 2 DL is the most precise and simple way to get lap times. Specifically designed for the Triumph this kit will ensure an improvement in your driving performance.
Database with more than 4,000 tracks worldwide Triumph ECU connection cable
This kit has been specifically designed for Triumph bikes. The kit comes with a cable for your bike. Connecting the Solo 2 DL to your Triumph ECU will give you all the engine performance information you need to help improve your driving performance.
The plug & play cable currently fits the following Triumph bike models:
Daytona 675 - 2006-2012 Street Triple - 2007-2012
Speed Triple - 2007-2012
The Triumph ECU interface cable provides a plug & play solution for connecting the Solo 2 DL lap timmer to your bike. Please refer to the technical sheet on how to connect the ECU cable to your bike.
Data Recall On Screen
  • Display: Graphical
  • Wi-Fi connection: Yes
  • GPS: 10 Hz
  • External power: 12 V
  • Memory: 4 GB
  • Pushbuttons: Metallic
  • Waterproof: IP67
Below is the pinout drawing for the Triumph plug & play connection cable.
  • Solo 2 DL
  • Power cable with AC adapter
  • User manual
  • AiM Triumph Connection Cable
  • GPS: 10 Hz
  • Memory: 4 GB
  • Waterproof: IP67
  • Solo 2 DL
  • User manual
