Skip to product information
1 of 5
Skoda Fabia R5 Aim SmartyCam 3 Corsa Kit - R5 2015 to 2018 - R5 EVO2 from 2019
SKU: skoda-SM3
€1.413,95 EUR
€1.413,95 EUR
Compact, Advanced, Precise
Enhance your Skoda Fabia R5's performance with the AiM SmartyCam 3 Corsa Kit, specifically designed for models from 2015 to 2018 and the EVO2 from 2019.
The NEW SmartyCam 3 Corsa saves all your information to a supported SD card for up to 2TB of data, this includes speed, RPM, lap number, gear shifts and many more features. With a built-in data logger running on an external power of 9-15 volts, the new SmartyCam 3 Corsa automatically powers on and off in-sync with your engine – and will start/stop recording for you. Analyse your data from a vast range of sources such as GPS track map, vehicle position and speed, lap & split times.
Skoda Fabia R5
Supported Models and years
  • Skoda Fabia R5
    2015 - 2018
  • Skoda Fabia R5 EVO2
    from 2019
These models feature a loom extension supplied by the car manufacturer which has a DTM 4 pin connector on one end carrying CAN and power supply contacts.
smartycam icon
smartycam icon
Standalone Feature
The SmartyCam 3 Corsa provides you with a CAN expansion that connects with many Aim devices such as the Solo 2 DL Laptimer, various Aim Dash Display Loggers, and PDM Dash systems. This is a standard practice within our products, however we have also equipped the SmartyCam 3 Corsa with unterminated CAN connections which allow you to connect the camera to any system as a standalone feature. No matter your vehicle and equipment, with the unterminated connectors you can run the Corsa through your CAN/ECU connections.
smartycam icon
Quality
smartycam icon
Anatomy
Finished with a sleek new look, the SmartyCam 3 Corsa is assured to add efficiency, informational data, productivity, and style to your racing. AiM SmartyCam 3 Corsa allows you to connect ECU directly to your camera with b connectors. Here at AiM, we provide only the best innovations and are constantly and consistently working to better your racing experience.
smartycam icon
Higher Storage Capacity
Generic HD cameras focus too much on pixel numbers resulting in large file sizes. The SmartyCam 3 footage has the same quality as other FHD cameras with smaller files due to H.264 compression system parameters being optimised to a perfect balance between video quality and file size. Choose between three file quality levels: O recording = 4GB (High Quality), 2GB (Normal Quality) or 1.5GB (Lower quality).
SD cards sold separately.
smartycam icon
The SmartyCam 3 Corsa Kit seamlessly integrates with the Skoda Fabia R5's ECU, providing real time data overlays for enhanced performance analysis. The SmartyCam 3 Corsa can be connected through the CAN network to our AiM Loggers, MX Series, MXL2, MyChron, Solo2 DL, EVO5 and ECU Bridge.
smartycam icon
Upgrade your Skoda Fabia R5 with the AiM SmartyCam 3 Corsa Kit today and experience unparalleled data insights for yourself!
  • Display resolution: 128 x 128 pixels
  • CMOS sensor: Global Shutter
  • Field of view: 67°, 84°
  • External power: 9-15 Volt
  • Connectors: 3 Binder 712 female 1 USB-C
  • Auto Power ON: Yes
  • Auto Power OFF: Yes
  • Dimensions: 102.2 x 63 x 46.5 mm
  • Weight: 280g, battery included
  • Waterproof: IP65-rated to withstand the rigours of motorsport, this kit offers durability and reliability for Skoda Fabia R5 drivers
smarty cam 3 sport connectors
smartycam 3 corsa pinout
Channels received by AiM devices configured with Skoda Fabia R5 protocol are:
Channel Name Function
RPM Engine speed
Gear Selected gear
Car Speed Vehicle speed
AccelPedal Pedal accelerator ratio
FrontBrkPress Front brake pressure
pHandBrake Handbrake pressure
SteeringPos Steering position Angle
TripDist2 Trip distance 2
GDUOutLed GDU output led
StRoadMode Status road mode (=1) - Special stage (=0)
  • SmartyCam 3 Corsa
  • USB-C Cable
  • 2m CAN Cable
  • 712 5 Pin Male
  • 4M Can Bus + Integrated 3.5 Female Jack For External Microphone Harness
Skoda Fabia R5
  • Skoda Fabia R5
    2015 - 2018
    from 2019
smartycam icon
smartycam icon
Standalone Feature
smartycam icon
Quality
smartycam icon
Anatomy
smartycam icon
smartycam icon
smartycam icon
Technical Specifications
Skoda Fabia R5 Protocol
RPM Engine speed
Gear Selected gear
What's In The Box
  • SmartyCam 3 Corsa
  • USB-C Cable
  • 2m CAN Cable
  • 712 5 Pin Male
