Link Nissan GTTLink - NGTTX PlugIn ECU
SKU: NGTTX
- €1.630,95 EUR
- €1.630,95 EUR
Link Nissan GTTLink - NGTTX ECU PlugIn ECU
The NGTTX is Designed to suit the grey plug RB (typically neo) engine.
Note, this ECU does not currently output the 4wd signal required for proper 4wd operation in 4wd Stages and skylines.
Suitable Applications:
RB20DE NEO, RB25DE NEO and RB25DET NEO in R34 Skylines
RB20DE NEO, RB25DE NEO and RB25DET NEO in C35 Laurels
RB20DE NEO, RB25DE NEO and RB25DET NEO in Nissan Stageas
- Plus, non-neo motors in Stages
Sequential fuel delivery
OEM idle hardware supported
CAN port
USB tuning cable included
Staged injection
Knock with "windowing"
I/O Expansion Options:
Expansion connector 1
Gnd Sensor Ground Only
DI 7 Digital Input
DI 8 Digital Input
An Volt 10 Analog 0-5V input
An Volt 9 Analog 0-5V input
Expansion connector 2
SGnd Sensor Ground Only
DI 5 Digital Input
DI 6 Digital Input
An Volt 5 Analog 0-5V input
An Volt 6 Analog 0-5V input
An Temp 2 Temperature sensor input
Pin 108 – OBD1 wire now used for IAT on Temp 4.
- G4X PlugIn ECU
- Stickers
RB20DE NEO, RB25DE NEO and RB25DET NEO in R34 SkylinesRB20DE NEO, RB25DE NEO and RB25DET NEO in C35 Laurels
CAN port
Staged injection
The following expansion connector inputs/outputs are provided:Expansion connector 1
DI 7 Digital Input
DI 8 Digital Input
DI 5 Digital Input
DI 6 Digital Input
- G4X PlugIn ECU
- Stickers
