Link E-Throttle G4 - #G4RET
SKU: RET
- €259,95 EUR
- €259,95 EUR
The Link external E-Throttle (Drive by Wire) module works with all Link's G4X ECUs (except the entry-level AtomX), plus all the G4+ ECUs (Storm and above) to give you full control of your throttle setup, allowing a faster more precise throttle response.
Replace your old mechanical throttle linkage with an advanced electronic throttle module. E-Throttle is faster responding, requires less maintenance, gives you better fuel economy and lower emissions.
The Link external E-Throttle (Drive by Wire) module works with all Link's G4X ECUs (except the entry-level AtomX), plus all the G4+ ECUs (Storm and above) to give you full control of your throttle setup, allowing a faster more precise throttle response. Replace your old mechanical throttle linkage with an advanced electronic throttle module. E-Throttle is faster responding, requires less maintenance, gives you better fuel economy and lower emissions.
The Remote E-throttle module is designed to be used with any Link G4X ECU (except the entry level AtomX) and any Link G4+ ECU (Storm and above). It is most commonly used to provide e-throttle control to the MonsoonX, StormX or PlugINX ECUs or secondary E-throttle control to the XtremeX or FuryX ECUs.
- Remote E-Throttle
