Laser Etched inserts for AiM CAN Expansion K Keypad
SKU: K-I-03
- €1,95 EUR
- €1,95 EUR
AiM CAN Expansion K Keypad - Laser Etched Inserts
We have an extensive range of laser-etched inserts available to suit any function applications required on your keypad.
15mm laser-etched inserts | Large range available |
Durable & removable | Spares |
Remote Button Interface Keypad - Laser Etched Inserts
We offer an extensive range of 15mm laser-etched inserts designed for our Remote Interface Keypads.
The inserts are 15mm in size and laser etched to a high standard, with a vast range of available icons to choose from to fit the keypads.
Please select as many inserts as you wish and add them to your shopping basket.
Please Note: The example shown above is to show how inserts will look in a keypad.
Custom your Keypad
With a fully customizable keypad, you can choose the application that's right for you.
The inserts are also easily substituted without having to take apart the keypad.
Custom your keypad in many applications such as Lights, Boost, Heating & Fans and Parking. The list is endless.
We have an extensive range of laser-etched inserts available to suit any function applications required on your keypad.Key Features :
We offer an extensive range of 15mm laser-etched inserts designed for our Remote Interface Keypads.The inserts are 15mm in size and laser etched to a high standard, with a vast range of available icons to choose from to fit the keypads.
Custom your Keypad
With a fully customizable keypad, you can choose the application that's right for you.The inserts are also easily substituted without having to take apart the keypad.
With Race Studio 3 you can also analyse all data recorded and downloaded to your PC: graphs, histograms and tables will help you study your performance, providing objective support to avoid mistakes and improve performances. ![]() |
- Inserts: Laser Etched
- Size: 15mm
- Laser-etched insert
- The amount depends on what is selected at checkout
