Kawasaki ZX-10R AiM Solo 2 & Solo 2 DL Motorcycle Bracket
SKU: KAW-B
- €82,95 EUR
- €82,95 EUR
The AiM Kawasaki motorcycle bracket has been specifically designed to provide a simple and secure mounting solution for the AiM Solo 2 and Solo 2 DL GPS Lap Timers.
Kawasaki bracket | All necessary mounting hardware |
Suitable for Solo 2 & Solo 2 DL | |
Kawasaki Solo 2 & Solo 2 DL Bracket
The Kawasaki ZX-10R bracket has been designed to provide a simple and secure way for mounting your Solo 2 or Solo 2 DL GPS Lap Timer on to your bike.
Please Note: For Kawasaki models from 2016.
Also available is our Kawasaki ZX-10R plug & play cable for the following bike models: (Sold Separately)
Kawasaki Ninja ZX-10R MY2011 - 2001-2015 | Kawasaki Ninja ZX-10R MY2011 Racing Kit - 2011-2015 |
Example data protocols
- Specifically designed Kawasaki ZX-10R bracket for the Solo 2 and Solo 2 DL
- 1 Bracket
- 2 toothed washers
- 2 Allen screws M6 x 12mm
The AiM Kawasaki motorcycle bracket has been specifically designed to provide a simple and secure mounting solution for the AiM Solo 2 and Solo 2 DL GPS Lap Timers.Key Features :
The Kawasaki ZX-10R bracket has been designed to provide a simple and secure way for mounting your Solo 2 or Solo 2 DL GPS Lap Timer on to your bike.Our brackets are supplied with all the necessary hardware required for fitting to your bike.
Also available is our Kawasaki ZX-10R plug & play cable for the following bike models: (Sold Separately)Kawasaki Ninja ZX-10R MY2011 - 2001-2015 | Kawasaki Ninja ZX-10R MY2011 Racing Kit - 2011-2015 |
- 1 Bracket
- 2 toothed washers
