Skip to product information
1 of 2
Kawasaki ZX-10R AiM Solo 2 DL Motorcycle Cable & Bracket
SKU: KAW-PP-KAW-B
€147,95 EUR
€147,95 EUR
The AiM Kawasaki motorcycle cable & bracket set has been specifically designed to provide a simple and secure mounting solution for the AiM Solo 2 DL GPS Lap Timers.
Kawasaki cable & bracket 7 pin - 712 male binder connection
Bracket suitable for Solo 2 & Solo 2 DL
Kawasaki Solo 2 DL Cable & Bracket
The AiM ECU plug & play cable has been specifically designed for the Kawasaki bike allowing easy installation to your Solo 2 DL via the 7 pin - 712 male connection cable. The ECU cable is an easy fitment to your bike and allows ECU data to be logged.
The AiM Kawasaki bracket has been designed to provide a simple and secure way for mounting your Solo 2 DL GPS Lap Timer onto your bike.
Please Note: For Kawasaki models From 2016.
The plug & play cable currently fits the following Kawasaki bike models:
Kawasaki Ninja ZX-10R MY2011 - 2001-2015 Kawasaki Ninja ZX-10R MY2011 Racing Kit - 2011-2015
Kawasaki Ninja ZX-10R MY2016 - From 2016 Kawasaki Ninja ZX-10R MY2016 Racing Kit - From 2016
Example data protocols
  • Specifically designed Kawasaki Plug & play cable and bracket for the Solo 2 DL
  • Below is the pinout drawing for the Kawasaki plug & play connection cable.
  • Kawasaki plug & play connection cable
  • 1 bracket
  • 2 toothed washers
  • 2 Allen screws M6 x 12mm
  • 1 bracket
  • 2 toothed washers
