Skip to product information
1 of 2
AiM PDM32 With 10" Road Icons Display GPS Data Logging Kit
SKU: PDM-32-10-I-XC1PDM32D10R400C2
€2.796,95 EUR
€2.796,95 EUR
The AiM PDM32 is a 32 channel advanced power distribution module designed to power a multitude of vehicle circuits, removing the need for traditional fuse boxes and relays. The 10" TFT display with road icons features a fully configurable display with a range of layouts to choose from and a GPS Module providing easy lap timing and lap position for track mapping.
32 RGB LEDs Eight analogue digital inputs
GPS lap timing (optional) Four digital inputs
28 High side outputs 4 Half-bridge outputs
Power Distribution Module
The PDM32 can receive data from the vehicle ECU and even includes a data logger and GPS Module for lap timing and track mapping. The GPS Module is available with cables from 50cm up to 4m. There is also a GPS roof version available in 2m or 4m.
PDM32 Power Outputs
PDM32 Inputs
PDM32 Data Management
Dash Display 10" Road Icons
10" TFT display Road Icons
Six - Status LEDs Ten - Shift light LEDs
The display also doubles up as a reversing mirror using a separately available camera—ideal for cars with limited rear vision. You can add up to 2 cameras for both front and rear views. You can find the optional Reversing Mirror Camera in the Accessories Tab.
Optional Wiring Solutions:
  • Inputs:
  • 14 Fully Configurable, max 500 Hz each:
  • 8 analogue/digital
  • 4 digital inputs
  • 2-speed input
  • Power Outputs:
  • 4 rated up to 20 A (high power)
  • 12 rated up to 15 A (mild power)
  • 12 rated up to 10 A (low bridge)
  • 4 rated up to 35 A (half-bridge)
  • Protected for: over voltage, under voltage, over current, over temperature
  • Total max current: 120 A
  • LEDs: 32 RGB LEDs + 1 PDM ON + 1 PDM STS (Status)
  • Lin Bus: 1
  • CAN Connections: 3
  • Internal platform: 3 axis ±5G accelerometer + 3 axis gyro + 3 axis magnetometer
  • Remote Display Connection: 1 AiM stream output
  • Connectors: 2 AMP connectors + 2 Binder connectors + 1 Amphenol Surlok connector + 1 Rosenberger connector
  • Internal memory: 4 GB
  • External modules: GPS Module, Channel Expansion, TC Hub, Lambda Controller, SmartyCam HD, Formula Steering Wheel, Remote I/O Pushbutton Module
  • External Analogue Camera input: 2
  • Body: Anodised Aluminium
  • Dimensions: 234.5 x 94.6 x 49.5mm
  • Weight: 761g
  • PDM Dash 10" TFT Display:
  • Display: 10" TFT
  • Contrast: 1,100:1
  • Brightness: 800cd/m2
  • Ambient Light Sensor: Yes
  • Status information LEDs: 6
  • Shift Light LEDs: 10
  • Body: Anodized Aluminium
  • Pushbutons: Metallic
  • Dimensions: 278.0 x 135.0 x 26.2mm
  • Weight: 1000 g
  • Power Consumption: 250 mA
  • GPS Module:
  • 5 Pin Binder connection
  • Weight: 60.5g
  • Power Distribution Module PDM32
  • TFT Screen 10" Road Icons
  • GPS Module
  • x 2 35 pins AMP Connector
  • Surlock Connector
  • Rosenberger LVDS Connector
  • CAN EXP Cable
  • Download Cable
PDM32 Power Outputs
PDM32 Inputs
  • Inputs:
  • 4 digital inputs
  • 2-speed input
  • Power Outputs:
  • Lin Bus: 1
  • Weight: 761g
  • Display: 10" TFT
  • Contrast: 1,100:1
  • Weight: 1000 g
  • GPS Module:
  • Weight: 60.5g
  • GPS Module
  • Surlock Connector
  • CAN EXP Cable
  • Download Cable
