Skip to product information
1 of 2
Aprilia RSV4 AiM Solo 2 DL Motorcycle Cable & Bracket
SKU: APR-PP-APR-B
€147,95 EUR
€147,95 EUR
The AiM Aprilia motorcycle cable & bracket set has been specifically designed to provide a simple and secure mounting solution for the AiM Solo 2 DL GPS Lap Timers.
Aprilia cable & bracket 7 pin - 712 male binder connection
Bracket suitable for Solo 2 & Solo 2 DL
Aprilia Solo 2 DL Cable & Bracket
The AiM ECU plug & play cable has been specifically designed for the Aprilia bike allowing easy installation to your Solo 2 DL via the 7 pin - 712 male connection cable. The ECU cable is an easy fitment to your bike and allows ECU data to be logged.
The AiM Aprilia bracket has been designed to provide a simple and secure way for mounting your Solo 2 DL GPS Lap Timer onto your bike.
Please Note: The bracket is only compatible with RSV4 original triple clamp.
The plug & play cable currently fits the following Aprilia bike models:
Aim Aprilia Motorcycle
Aprilia RSV4 RR/RF - From 2017 Aprilia RSV4 1100 - From 2019
Aprilia Tuono V4 RR/Factory - From 2017
Example data protocols
  • Specifically designed Aprilia RSV4 Plug & play cable and bracket for the Solo 2 DL
  • Below is the pinout drawing for the Aprilia plug & play connection cable.
  • Aprilia plug & play connection cable
  • 1 bracket
  • 1 toothed washer
  • 1 rubber dowel
  • 1 bracket
  • 1 toothed washer
  • 1 rubber dowel
