Skip to product information
1 of 3
AiM Two-way Data Hub CAN Connection Multiplier with External Power Car
SKU: S-2PH
€79,95 EUR
€79,95 EUR
The AiM two-way Data Hub provides CAN channels and works as an interface between our AiM loggers and sensors. It also features a 12V external power connection.
Five pins 712 male Binder Two-way hub
Two flying cables Build a network
Two-Way Data Hub with External Power Connection
The compact two-way data hub with 12V flying leads provides a CAN channel and works as an interface between our Loggers and equipment such as LCU Lambda Controller, GPS Module, TC Hub, SmartyCams and many more.
The two-way Data Hub takes all the information you need to your logger with only one cable, minimizing wires overall.
The two-way data hub is beneficial as the external power allows you to connect different devices powering them through a battery.
Four-way data hub
Two-way data hub
AiM Two-way Data Hub CAN Connection Multiplier with External Power Kart
  • Dimensions: 70 x 30 x 23.5mm
  • CAN cable length: 40cm
  • Source cable length: 165cm
  • Weight: 86g
  • 5 pin 712 male Binder connection
  • Two flying leads 12V
  • x 1 Two-way Data Hub with external power
Four-way data hub
Two-way data hub
  • Weight: 86g
