Skip to product information
1 of 7
Aim Solo 2 DL Motorcycle Plug & Play Data Logging Kit
SKU: SOLO2-K-YAM-4-ACC-SUS-POT-75-SUS-POT-150-S-P-B-M10-BP-DB-P-719-719-5-P-719-719-5-P-719-719-10
€2.177,95 EUR
€2.177,95 EUR
"Model" is required
"Lambda Controller (Data Hub included)" is required
"Smartycam Options (Data Hub included)" is required
"Four-way Data Hub" is required
"Mounts" is required
Total:
€1.795,00
Top Banner
Solo 2 DL
The Solo 2 DL can handle an ECU input with a CAN expansion port that you can connect a SmartyCam to.
The data you record typically includes RPM, throttle position (TPS), oil, air, water temperature, oil pressure, battery voltage, speed, gear and lambda value (air/fuel).
Bike-Specific Plug & Play Cable
The kit comes with a cable to connect the Solo 2 DL to your bike, relaying all vital ECU information. The cable is specific to your bike model.
Brake Pressure
Sensor
Brake pressure sensors are used to measure how much force is applied by the rider to the brake, when combined with suspension potentiometers, you can get a greater understanding of your bike setup.
Suspension Potentiometer
The suspension potentiometer is used to measure the travel of the suspension forks on your motorbike and therefore helps to understand your suspension setup.
ACC (Analogue
CAN Converter)
The ACC provides virtually endless data acquisition and system expansion options. ACC adds four freely configurable analogue/digital channels without occupying or modifying the existing system channels.
AiM Solo 2 DL Motorcycle Plug & Play Data Logging Kit
This plug & play kit with the Solo 2 DL gives you the ultimate track day experience.
It includes the Solo 2 DL, 2 suspension potentiometers, an analogue CAN converter (ACC), a brake pressure sensor, and a bike-specific plug & play cable.
Key Features:
Database with more than 4,000 tracks worldwide ECU connection cable
The plug & play cable currently fits the following bike models:
→Aprilia
→BMW
→Ducati
→Honda
→MV Agusta
→Suzuki
→Triumph
→Yamaha
Powerful Combination
AiM Solo 2 DL is the most precise GPS lap timer there is with the ability to show you your lap time live as you drive. Receiving data from two satellite constellations from anywhere on the globe by using GPS and Glonass also gives you a significant improvement in data speed and positioning precision.
The ECU interface cable provides a plug & play solution for connecting the Solo 2 DL lap timmer to your bike. Please refer to the technical sheet on how to connect the ECU cable to your bike.
The Solo 2 DL has a sharp, high-contrast display which helps drivers easily identify the data displayed on the screen. The Solo 2 DL also features a selection of 7 different backlight colours which can be selected to suit your requirements.
Solo 2 DL allows you to simply create a new temporary or permanent track layout whether it's a point-to-point run for rallying or a closed-loop track it can simply be added to the Solo 2 DL and PC database.
Triumph
Top Banner
Solo 2 DL
Brake Pressure
Sensor
ACC (Analogue
CAN Converter)
Key Features:
→Aprilia
→BMW
→Ducati
→Honda
→MV Agusta
→Suzuki
→Triumph
→Yamaha
  Triumph
  • Display: Graphical
  • Wi-Fi connection: Yes
  • GPS: 10 Hz
  • External power: 12 V
  • Memory: 4 GB
  • Pushbuttons: Metallic
  • Waterproof: IP67
    ACC
  • Analogue channels: 4 channels, 0÷5 V, 12 bit A/D, 200 Hz each
  • External power: 9÷15 V Full operation
  • Connection: CAN
  • Connectors: 2 Binder 712 fem connectors
  • Material: PA6 30% glass
  • Dimensions: 44.0 x 38.0 x 19.8 mm
  • Weight:50 g
Please refer to the Technical sheets in the Downloads Tab for all other diagrams for Solo2 DL.
Below is the pinout drawing for the plug & play connection cable.
  • Solo 2 DL
  • Power cable with AC adapter
  • External CAN cable 2m
  • External power cable
  • Plug & Play connection cable
  • Suspension Potentiometer
  • ACC
  • Brake Pressure Sensor
