AiM SmartyCam HD 2.1 & SmartyCam 3 Roll Cage Mount Kart
SKU: SM-VB-K
- €72,95
- €72,95
The SmartyCam can be installed using the roll cage mount. It is suitable for SmartyCam HD 2.1 & SmartyCam 3.
Secure mounting for SmartyCam | Ball & socket system |
Suitable for 0.5 to 1.2" | For SmartyCam HD 2.1 & SmartyCam 3 |
The AiM SmartyCam roll cage mount allows you to mount your SmartyCam to your car/motorcycle.
The SmartyCam roll cage mount has been designed to securely mount the AiM SmartyCam camera.
The V bracket adjusts by using the ball and socket type system for optimising positioning and simply clamps to roll bars of a wide range of diameters.
Please Note: This bracket is only suitable for the SmartyCam HD 2.1 & SmartyCam 3.
Roll Cage Mount
Securely clamps to a roll bar of a wide range of diameters.
- 1 Handlebar bracket and straps
- 160mm single ball arm
- 1 ball head
- 1 washer diameter 17.7mm, thickness 1.5mm, hole 6mm
The SmartyCam can be installed using the roll cage mount. It is suitable for SmartyCam HD 2.1 & SmartyCam 3.Key Features :
![](https://cdn.shopify.com/s/files/1/0214/9392/files/AiM_SmartyCam_HD_2.1_Roll_Cage_Mount_main_description.png?v=1618846499)
The AiM SmartyCam roll cage mount allows you to mount your SmartyCam to your car/motorcycle.The SmartyCam roll cage mount has been designed to securely mount the AiM SmartyCam camera.
Roll Cage Mount
A solid ball and socket type system provides an adjustable and very strong mounting.Securely clamps to a roll bar of a wide range of diameters.
![](https://cdn.shopify.com/s/files/1/0214/9392/files/Free_Download.png?v=1629297377)
- 1 ball head
![AiM SmartyCam HD 2.1 & SmartyCam 3 Roll Cage Mount Kart - AimShop.com](http://www.aimshop.com/cdn/shop/products/SmartyCam_HD_Roll_Cage_Mount_-2_482643be-bf15-42b5-8d8d-659174e248d3_1445x.jpg?v=1581687001)
![AiM SmartyCam HD 2.1 & SmartyCam 3 Roll Cage Mount Kart - AimShop.com](http://www.aimshop.com/cdn/shop/products/SmartyCam_HD_Roll_Cage_Mount_24074a51-925b-44ed-a95b-ceb424502bd2_1445x.jpg?v=1581687001)
