AiM SmartyCam 2.1 HD & SmartyCam 3 Roll Cage Mount Motorcycle
SKU: SM-VB-X90KSSMC0
- €74,95 EUR
- €74,95 EUR
The SmartyCam HD can be installed using the HD roll cage mount. It is suitable for SmartyCam HD 2.1 & SmartyCam 3.
Secure mounting for SmartyCam | Ball & socket system |
Suitable for 0.5 to 1.2" | For SmartyCam HD 2.1 & SmartyCam 3 |
The AiM SmartyCam roll cage mount allows you to mount your SmartyCam to your car/motorcycle.
The SmartyCam roll cage mount has been designed to securely mount the AiM SmartyCam camera.
The V bracket adjusts by using the ball and socket type system for optimising positioning and simply clamps to roll bars of a wide range of diameters.
Please Note: This bracket is only suitable for the SmartyCam HD 2.1 & SmartyCam 3.
Roll Cage Mount
Securely clamps to a roll bar of a wide range of diameters.
- Arm height 160mm ( 6.30 inches)
- 1 Handlebar bracket and straps
- 160mm single ball arm
- 1 ball head
- 1 washer diameter 17.7mm, thickness 1.5mm, hole 6mm
The SmartyCam HD can be installed using the HD roll cage mount. It is suitable for SmartyCam HD 2.1 & SmartyCam 3.Key Features :
The AiM SmartyCam roll cage mount allows you to mount your SmartyCam to your car/motorcycle.The SmartyCam roll cage mount has been designed to securely mount the AiM SmartyCam camera.
Roll Cage Mount
A solid ball and socket type system provides an adjustable and very strong mounting.Securely clamps to a roll bar of a wide range of diameters.
- 1 ball head
