Skip to product information
1 of 2
AiM Power Distribution Module PDM08 with GPS Module
SKU: PDM-8-05-XC1PDM0801G050
€1.548,95 EUR
€1.548,95 EUR
The AiM PDM08 is an 8 channel advanced power distribution module designed to power a multitude of vehicle circuits, removing the need for traditional fuse boxes and relays. This kit also comes with a GPS Module.
8 RGB LEDs Six analogue digital inputs
GPS lap timing (optional) Power outputs
The AiM PDM08 is a 8 channel advanced power distribution module designed to power a multitude of vehicle circuits, removing the need for traditional fuse boxes and relays. It allows for a simplified wiring harness with increased reliability and control functions.
The PDM08 is available on its own or with a choice of 6" or 10" dash displays. It can receive data from the vehicle ECU and even includes a data logger and optional GPS module for lap timing and track mapping.
PDM08 Power Outputs
The PDM8 features eight high sided outputs: 1 x with series diode rated up to 20A, 1 x rated up to 25A, 6 x rated up to 15A. Total continuous max current 100A.
Each of the outputs provides feedback to the data logger to provide vital information such as open circuits, short circuits, high/low voltage, the number of fault retires, and the time between the reties is user-definable.
PDM08 Inputs
The PDM08 features 6 x analogue/digital inputs, and 2 x speed inputs.
PDM08 Data Management
The PDM08 can receive and record data from the following sources, ECU - Over 1000 protocols available. Digital/analogue inputs. Internal nine-axis EMU. GPS - Lap time and position.
Dash Display Options
Suitable for replacing all of the dashboard gauges and warning lamps, these TFT dash displays are available in 6" or 10" versions and with "Race" or "Road" icons. Both versions have full user-configurable displays and offer a range of layouts.
GPS Options Available With This Kit
The GPS09 module is available with various lead lengths to suit different applications and with cable entry from underneath (roof version) or the side.
Optional Wiring Solutions
  • LEDs: 8 RGB LEDs + 1 PDM ON + 1 PDM STS (Status)
  • Inputs:
  • Six fully configurable, max 500 Hz each
  • Pullup + 12V, + 5V, analog/digital
  • Pulldown
  • Speed In: 2
  • Power Outputs:
  • 1 with serie diode rated up to 20 A
  • 1 rated up to 25 A
  • 6 rated up to 15 A
  • Protected for:
  • Over Voltage, Under Voltage, Over Current, Over Temperature
  • All inputs have an internal freewheeling diode
  • Total max current: 100 A
  • Lin Bus: 1
  • CAN Connections: 3
  • Internal Platform: 3 axis ±5G accelerometer + 3axis gyro + 3 axis magnetometer
  • Internal Memory: 4 GB
  • External Modules: GPS Module, Channel Expansion, TC Hub, Lambda Controller, SmartyCam HD, Formula Steering Wheel, Remote I/O pushbutton module
  • External Analog Camera input: NO
  • Connectors: 1 AMP connector + 1 Amphenol Surlok connector + 1 Rosenberger connector
  • Remote display connection: 1 AiM stream output
  • Body: Anodized Aluminium
  • Dimensions: 161 x 100.6 x 50.6mm
  • Weight: 500 g
  • GPS Module:
  • 5 Pin Binder connection
  • Dimensions: 64.8 c 53.2 x 19.7mm
  • Weight: 60.5g
  • Power Distribution Module PDM08
  • Surlok Power Connector
  • GPS Module
PDM08 Power Outputs
PDM08 Inputs
  • Inputs:
  • Pulldown
  • Speed In: 2
  • Power Outputs:
  • Protected for:
  • Lin Bus: 1
  • Weight: 500 g
  • GPS Module:
  • Weight: 60.5g
  • GPS Module
