AiM MXS, MXP & MXL2 Dash Bracket
SKU: UP-MXL
- €24,95 EUR
- €24,95 EUR
MXS / MXP / MXL2 Dash Bracket
This bracket has been designed to mount the MXS / MXP / MXL2 dash.
Key Features:
MXS, MXP, MXL2 Dash Bracket
Due to the size of the Dash, this will probably more likely be used with our single mount centre hub on the steering column or our chassis weld-on and bolt-on tabs. Though this will work without steering wheel mounts if you prefer. Optional Weld on the tab for your chassis or steering column. 2mm thick in Raw Stainless Steel Our Modular Steering Wheel Components are Stainless Steel (raw finish) interchangeable components to facilitate the mounting of displays/buttons/dash/lap timer/shift lights. |
AiM Technologies are committed to supplying, professional engineers with quality Motorsport products. Our cables and accessories are well-engineered and designed for demanding motorsport applications and the demands that racing puts on components. Which makes ours amongst the best in the marketplace today. |
Unlock your potential |
- 160mm x 60mm bolt holes for dash
- 2mm thick in raw stainless steel
Key Features:
Whats In The Box
