Aim MXm Legends Kit Compact Dash Display
SKU: MXM-LEGEND-X87MXM0007
- €1.214,95 EUR
- €1.214,95 EUR
The Aim MXm display has been designed to specifically suit Legends race cars, 2018 onwards, fitted with a 3-cylinder Yamaha FZ09 engine.
MXm Legends Key Features
Why Choose The Aim MXm Legends Compact Dash Display
This compact MXm display has been designed to specifically suit Legends race cars, 2018 onwards fitted with the 3-cylinder Yamaha FZ09 engine. The Legends cars specific 37 pin Deutsch connector harness allows connection to the vehicle battery and ECU directly, through the 8 pins white JST connector (labelled “ECU”), and to the onboard gear sensor, through the 6 pins white Sumitomo connector (labelled “CH. 1”).
The unit features advanced data logging capabilities and is designed for racers needing all the essential information to monitor the behaviour of their vehicles and to improve their performance. Designed to acquire and display data coming from your ECU, as well as from the internal GPS receiver, analogue/digital inputs and predefined math channels.
Aim MXm Legend Compatibility
This kit is compatible with Legends Cars (with a 3-cylinder Yamaha FZ09 engine) from 2018 onwards
Please Note: If you are unsure if this cable will fit your car, don't hesitate to contact our team.
Integrated Shift Lights and Alarms
The display has an integrated shift light system that features 5 fully configurable LEDs which can be customised to your requirements and for each gear. Two further LEDs can be configured to operate as warning alarms. These warning lights can be customised for a particular parameter that requires a warning light, the colour of the LED, and whether you want a solid or a flashing style alarm, even the flashing frequency can be tailored to suit your requirements.
Sharp Liquid Crystal Display
Making use of a sharp liquid crystal screen, the user can select the information that is displayed and the backlight can be switched between 7 available colours, all with high contrast and easy-to-read graphics. The information that is displayed on the screen can be fully configured by the user to prioritise the most important information for the driver. If there is simply too much information to be shown on the screen, the driver can scroll between multiple pages using the integrated buttons so that nothing is missed.
After the session has concluded, all of the data can be recalled on the screen including a summary of the driver's best laps along with max/min RPM, speed and temperatures. If you would prefer to go through the data in more detail, the MXm features a Wi-Fi function to enable fast and secure data transfer to a laptop or PC up to 50 meters away, so you no longer need to take the laptop to the car.
These are only some of the items that can be added to our MXm for incrementing the performance and the data acquired.
With Race Studio 3, you can also analyse all data recorded by the MXm and download it to your PC: graphs, histograms and tables will help you study your performance, providing objective support to avoid mistakes and improve performance.
Technical Specifications
- Ambient Light Sensor: Yes
- Shift Lights: 5 configurable RGB LEDs
- Alarm LEDs: 2 configurable RGB LEDs
- CAN Connections: 2
- ECU Connections: CAN, RS232, K-Line
- ECU Compatibility: +1,000 industry-leading ECUs
- GPS: Integrated
- External Modules: Lambda Controller, SmartyCam HD
- Analogue Inputs: 4 fully configurable, max 1,000 Hz each
- Digital Inputs: 2-speed inputs, coil RPM input
- Digital Outputs: 2 high side
- Wi-Fi Connection: Yes
- Internal Memory: 4GB
- Body: Glass fibre reinforced Nylon
- Connectors: 37 pins Motorsport connector for Legends Cars + 4 pins power connector
- Weight: 330g
- 37 pins harness spec below:
- x1 6 pins male Sumitomo - On-board gear sensor connection
- x3 4 pins 719 female binder - Analogue sensors connection
- x2 4 pins 719 female binder - Speed inputs
- x2 5 pins 712 female binders ("Y" cable) - Aim Expansions connection (labelled CAN EXP)
- X1 4 pins 719 female binder - USB connection
- x1 8 pins JST connector - ECU + external power connection (labelled ECU)
What's In The Box
- MXm Dash Display
- 37 pins connector harness for Legends Cars
- 4 pins secondary connector kit for power output connection (up to 15A each)
