Skip to product information
1 of 2
AiM Motocross Microtec M206 & M222 ECU Solo 2 DL Plug & Play Lead
SKU: MIC-MX-PP
€82,95 EUR
€82,95 EUR
AiM Motocross Microtec ECU Solo 2 DL Plug & Play Lead
The AiM ECU plug & play cable has been specifically designed for dirt bikes. Allowing easy installation to a Solo 2 DL. With a 7-pin 712 male binder connection.
Microtec plug & play cable 7 pin - 712 male binder connection
Microtec Plug & Play ECU Cable
The AiM ECU plug & play cable has been specifically designed for dirt bikes. This plug & play cable can be used for the Solo 2 DL.
Suppered models are:
Microtec M222 ECU Microtec M206 ECU
Example data protocols
AAiM Motocross Microtec ECU Solo 2 DL Plug & Play Lead
  • Below is a pinout drawing for the Microtec Solo 2 DL plug & play connection cable
  • Microtec Plug & Play connection cable
