Skip to product information
1 of 2
AiM Motocross Honda Solo 2 DL Plug & Play Lead
SKU: HON-MX-PP
€82,95 EUR
€82,95 EUR
The AiM ECU plug & play cable has been specifically designed for Honda bikes. Allowing easy installation to a Solo 2 DL. With a 7-pin 712 male binder connection.
Honda plug & play cable 7 pin - 712 male binder connection
Honda Plug & Play ECU Cable
The AiM ECU plug & play cable has been specifically designed for the Honda bikes. This plug & play cable can be used for the Solo 2 DL.
Honda CRF 250 cc - From 2010 onwards Honda CRF 450 cc - From 2009 onwards
Example data protocols
  • Below is a pinout drawing for the Honda Solo 2 DL plug & play connection cable
  • Honda Plug & Play connection cable
