AiM EVO4S Motorcycle Racing Data Logger
SKU: EVO4S
- €1.453,95 EUR
- €1.453,95 EUR
AiM EVO4S Car Racing Datalogger
The EVO4S is a powerful and flexible data logger, offering a wide range of sources for your data. A great tool for track days to help improve your performance.
Many options for ECU connection | Includes GPS Module |
Built-in accelerometer & gyro sensor | CAN output |
5 fully configurable analogue channels | 2-speed inputs |
AiM EVO4S Data Logger
The AiM EVO4S is a powerful and flexible data logger and comes equipped with a GPS Module. Offering one connector per channel the EVO4S samples all the information you need, data coming from your vehicle's ECU via CAN, RS232 or K-Line, from the internal accelerometers and gyro and the GPS Module included in the kit.
Select which harness you require CAN, RS232 or OBD11, and select which GPS Module best meets your requirements. You can also upgrade your kit with our GS -Dash display and Formula 3 steering wheel, allowing you to really improve your performance on track days.
Sensors
4GB memory
RPM input manages square wave signals transmitted by the ECU, or pulse signals picked from the coil command (low voltage).
- ECU Connection: CAN, RS232, K-Line
- External Modules Connection: GPS Module, Channel Expansion, TC Hub, Lambda Controller, SmartyCam HD
- Analog Inputs: 5 fully configurable, max 1,000 Hz each
- Inertial Platform: Internal 3 axis ±5G accelerometer + 3 axis gyro
- Internal Memory: 4GB
- Body: Anodized Aluminium
- LEDs: 1 system staus
- Weight: 330g
- EVO4S Data Logger
- Harness of Your Choice
- Power Cable
- Download Cable
- RPM Harness
- GPS Module
- Mounting Bracket
The EVO4S is a powerful and flexible data logger, offering a wide range of sources for your data. A great tool for track days to help improve your performance.Key Features :
The AiM EVO4S is a powerful and flexible data logger and comes equipped with a GPS Module. Offering one connector per channel the EVO4S samples all the information you need, data coming from your vehicle's ECU via CAN, RS232 or K-Line, from the internal accelerometers and gyro and the GPS Module included in the kit.From analogue/digital inputs, external expansions as well as predefined math channels. Sensors can be connected to 5 configurable analogue channels, to the RPM input and to 2 wheel speed inputs.
Sensors
5 fully configurable analogue channels with configurable 12-bit o-5 Volt, 0-5000 mV inputs or thermocouple input, used to sample data coming from the temperature, pressure, suspension and other sensors.2-speed inputs which will allow you to monitor different wheel behaviours.
4GB memory
You can add optional expansion modules via the built-in CAN bus.Channel Expansion: Permits to add 4 0-5volt analogue channels for pressure, temperature sensors and potentiometers (suspension, steering angle). Two of these channels can be configured to receive digital inputs like wheel speed.
These are only some of the items that can be added to our EVO4S for incrementing the performance and the data acquired.Configure & Analyse with Race Studio 3
With Race Studio 3 you can also analyse all data recorded by EVO4S and downloaded to your PC: graphs, histograms and tables will help you study your performance, providing an objective support to avoid mistakes and improve performance.Technical
- Weight: 330g
- EVO4S Data Logger
- Power Cable
- Download Cable
- RPM Harness
- GPS Module
- Mounting Bracket
