Aim Axle Rear Speed Pickup Sensor
SKU: S-S-K-R-X05SNVB301
- €84,95 EUR
- €84,95 EUR
Rear Speed Pick Up Sensor
The AiM wheel speed non-contact sensor for MyChron4 & MyChron5 S.
Key Features:
The AiM Axle rear speed pickup sensor is suitable for use with the MyChron5 S and MyChron5 S 2T, also including our older models MyChron5 and MyChron4 Kart Dash / Data Loggers. |
AiM Technologies are committed to supplying, professional engineers with quality Motorsport products. Our cables and accessories are well-engineered and designed for demanding motorsport applications and the demands that racing puts on components. Which makes ours amongst the best in the marketplace today. |
Unlock your potential |
Key Features:
AiM Axle Rear Speed Pickup Sensor
Sensor Electrical Characteristics:
- Power Tension: 6-24 VDC
- Power Supply: 13.5 mA
- Output Signal Type: Pulse 0-5 volt
- Max Current Output: 20 mA
- Max Operating Frequency: 100kHz
- Max Sensibility Distance: 20mm
- Recommended Distance: 10mm
- Number of Pulses for Wheel Revolution: 1
Sensor Mechanical Characteristics:
- Operating Temperature Range: From -20 to +85° C
- Cable Length: 1700mm
Whats In The Box
- Rear Speed Wheel Sensor
- 3 Nuts
- 1 Screw
