AiM ACC Analogue CAN Converter
SKU: ACC
- €302,95
- €302,95
![logo](https://cdn.shopify.com/s/files/1/0214/9392/files/logo_acc.png?v=1696335322)
ENHANCE YOUR LOGGER PERFORMANCE ACC is the new compact and powerful Analogue CAN Converter that manages up to four channels at 200 Hz each. Now compatible also with the AiM Solo 2 DL.
![](https://cdn.shopify.com/s/files/1/0214/9392/files/back_visual_2_22be472c-e833-4fc5-ab96-edb0675f0c61.jpg?v=1702980019)
ACC - Analogue CAN Converter
- Analogue channels: 4 fully configurable channels, 24 bit, A/D, 200 Hz each: TC (with dedicated cable), TR, 0÷5 V, 0÷12 V
- External power:9÷15 V operational 12÷15 V fully operationa
- Connection: CAN
- Connectors: 2 Binder 712 fem connectors
- Material: PA6 30% glass
- Dimensions: 44.0 x 38.0 x 19.8 mm
- Weight:50 g
![Acc tech sheet](https://cdn.shopify.com/s/files/1/0214/9392/files/Capturing_91c1d3c0-649d-4ced-94a5-ac26c4f8f20a.png?v=1696002771)
- Converter
- CAN cable 100cm
- 4 channels harness
ConfigurationWith Race Studio 3 you can create, modify, delete, import and export configurations with all channels, ECU drivers, Math channels, Display Pages, Digital outputs, Alarms, Shift Lights and all the expansions you need. You will also be able to manage the map of all your racing tracks and compare two laps watching the video recorded by SmartyCam HD cameras.
With Race Studio 3, you can also analyse all data recorded and downloaded to your PC: graphs, histograms and tables will help you study your performance, providing objective support to avoid mistakes and improve performances. ![]() |
- Connection: CAN
- Weight:50 g
- Converter
- CAN cable 100cm
![AiM ACC Analogue CAN Converter - AimShop.com](http://www.aimshop.com/cdn/shop/files/AiMACCofficialphoto2_1445x.jpg?v=1696233427)
![AiM ACC Analogue CAN Converter - AimShop.com](http://www.aimshop.com/cdn/shop/files/AiMACCofficialphoto1_1445x.jpg?v=1696233427)
![AiM ACC Analogue CAN Converter - AimShop.com](http://www.aimshop.com/cdn/shop/files/AiMACCofficialphoto3_1445x.jpg?v=1696233423)
