1 von 5
Suzuki Solo 2 DL SmartyCam 3 Bullet Camera Kit
SKU: SOLO2-K-SUZ-SM-GPC-SM-CAM-GP-2
Regulärer Preis
£2,060.00
Regulärer Preis
Verkaufspreis
£2,060.00
Suzuki GSX-R 1000/750/600 AiM Solo 2 DL & SmartyCam 3 GP Motorcycle Plug & Play Lap Timer Track Day Kit
The Suzuki GSX-R 1000/750/600 plug & play kit combined with the Solo 2 DL and SmartyCam 3 GP gives you the ultimate track day experience.
Database with more than 4,000 tracks worldwide Suzuki ECU connection cable
Suzuki GSX-R
This ultimate track day kit has been specifically designed for Suzuki bikes. The kit includes a plug & play interface cable and bracket for your bike. A Solo 2 DL to give you the most precise lap times and the incredibly robust SmartyCam 3 GP to record your races and provide all the technical layovers to help improve your performance. Also added is our 3 GP bullet camera clamp mount to enable you to position the bullet camera on your bike. Connecting the Solo 2 DL to your Suzuki ECU will give you all the engine performance information you need to help improve your driving performance.
SmartyCam 3 GP Features:
GSX-R 1000 L7 - 2017 onwards GSX-R750 - 2006-2019
GSX-R600 - 2006-2022 GSX-R1300 Hayabusa Gen.2 - 2008-2016
Powerful Combination
The Suzuki GSX-R 1000 L7 ECU interface cable provides a plug & play solution for connecting the Solo 2 DL lap timmer to your bike. Please refer to the technical sheet on how to connect the ECU cable to your bike.
SmartyCam 3 GP
Automatic Start/Stop
Suzuki GSX-R
Suzuki GSX-R 1000 L7 AiM Solo 2 DL & SmartyCam 3 GP Motorcycle Plug & Play Lap Timer Track Day Kit
  • Display: Graphical
  • Wi-Fi connection: Yes
  • GPS: 10 Hz
  • External power: 12 V
  • Memory: 4 GB
  • Pushbuttons: Metallic
  • Waterproof: IP67
  • SmartyCam 3 GP
  • CMOS sensor: Global Shutter
  • Video Out: 3G-SDI
  • External power: 9-15 Volt
  • Auto Power ON: Yes
  • Auto Power OFF: Yes
  • Body: Anodised Aluminium
  • Waterproof: IP65
Below is the pinout drawing for the Suzuki GSX-R 1000 L7 plug & Play connection cable.
  • Solo 2 DL
  • Power cable with AC adapter
  • SmartyCam 3 GP - Bullet Cam
  • External CAN cable 2m
  • External power cable
  • Suzuki Plug & Play connection cable
  • 1 Bracket
  • 1 toothed washer
  • 1 rubber dowel
Suzuki GSX-R
SmartyCam 3 GP
Suzuki GSX-R
  • GPS: 10 Hz
  • Memory: 4 GB
  • Waterproof: IP67
  • SmartyCam 3 GP
  • Video Out: 3G-SDI
  • Waterproof: IP65
  • Solo 2 DL
  • 1 Bracket
  • 1 toothed washer
  • 1 rubber dowel
