Super B Mason 12V25Ah BMS Lithium Battery
SKU: SB-25-M
- Regulärer Preis
- £1,110.00
- Regulärer Preis
- Verkaufspreis
- £1,110.00
- Stückpreis
- pro
Super B Mason 12V25Ah Lithium Battery
The new Mason 12V25Ah power battery is light-weighted, compact and offers high performances. Thanks to its lithium iron phosphate technology and integrated BMS system this new generation battery is extremely reliable and offers optimal safety. This battery is developed for motorsport, motorcycle, automotive and marine applications. Suitable for 12V systems and for use in extreme environments.
Lightweight PowerWith a weight of ±5.2kg /11.46lbs, the Mason 12V25Ah power battery saves up to 60% in weight in comparison to traditional lead-acid batteries and is only 1/3 of the size of a conventional battery. This improves not only the performance of your vehicle but also helps to increase the fuel economy. The battery offers a high level of power, fast charging and a long, maintenance free service life. It also has a stable and flat discharge which means you have over 80% of the batteries capacity available. |
Integrated BMSThe Mason 12V25Ah power battery incorporates a Battery Management System (BMS) to ensure a high level of safety during use. The BMS constantly monitors the status of individual battery elements such as cell temperature, cell voltage, charge and discharge currents. The integrated BMS also provides cell balancing.
Safe & ReliableDue to its high ingress protection class (IP66) the battery is dust tight and waterproof. Therefore the battery can be used in the most extreme environments as well. Performance |
Fast charging | ||
Lightweight | ||
Long and maintenance-free lifespan | ||
Compact size | ||
Low self-discharge | ||
Integrated BMS |
Safest Lithium Iron Phosphate Technology (LFP) |
ELECTRICAL SPECIFICATIONS
Energy 320Wh
Nominal Voltage 12.8V
Open Circuit Voltage 13.2V
Self Dischrage <3% per month
EqPb (Equals lead-acid) 100 to 130Ah
MECHANICAL SPECIFICATIONS
Weight 5.2 kg / 11.46lbs
Case Material PC - ABS
Ingress Protection IP66
Charge Voltage 14.3V - 14.6V
Max Charge Current 77A
End of Discharge Voltage 8V
Discharge Current Continuous 260A
Discharge Pulse Current (1 sec) 1000A (40C)
TEMPERATURE SPECIFICATIONS
Discharge Temperature -20°C to 55°C | -4°F to 131°F
Storage Temperature -20°C to 45°C | -4°F to 113°F
COMPLIANCE SPECIFICATIONS
Battery Designation 4IFpR27/66-10
Lightweight PowerWith a weight of ±5.2kg /11.46lbs, the Mason 12V25Ah power battery saves up to 60% in weight in comparison to traditional lead-acid batteries and is only 1/3 of the size of a conventional battery. This improves not only the performance of your vehicle but also helps to increase the fuel economy.The battery offers a high level of power, fast charging and a long, maintenance free service life. It also has a stable and flat discharge which means you have over 80% of the batteries capacity available. |
Integrated BMSThe Mason 12V25Ah power battery incorporates a Battery Management System (BMS) to ensure a high level of safety during use. The BMS constantly monitors the status of individual battery elements such as cell temperature, cell voltage, charge and discharge currents. The integrated BMS also provides cell balancing. |
Fast charging | ||
Lightweight | ||
Compact size | ||
Integrated BMS |
Energy 320Wh
Data Sheet
Guide
User Manual
