SmartyCam 3 Dual
SKU: SM3-D
- Regulärer Preis
- £1,480.00
- Regulärer Preis
- Verkaufspreis
- £1,480.00
- Stückpreis
- pro
+ MwSt. (nur Großbritannien)
Dual Full HD camera system, Video output, CAN connection, USB-C connection, Ethernet port are only few of the features of SmartyCam 3 Dual: the most powerful of our range.
The new SmartyCam 3 Dual saves all your information to a supported SD card for up to 2TB of data, this includes speed, RPM, lap number, gear shifts and many more features. With a built-in data logger running on an external power of 9-15 volts, the new SmartyCam 3 Dual automatically powers on and off in-sync with your engine – and will start/stop recording for you. Analyse your data from a vast range of sources such as GPS track map, vehicle position and speed, lap & split times. Video format is at H.264 1920x1080 pixels, 60 FPS, and the display resolution of 2.4” 240x320 pixels gives your footage crisp condition. Our quality doesn’t falter, even under the pressure of extreme motorsport conditions such as poor weather, strong vibrations, continuous rain, and high/low temperatures as extreme as -10°C to + 50°C. Our camera is also waterproof (IP65) for extra protection.
![smartycam icon](https://cdn.shopify.com/s/files/1/0214/9392/files/SmartyCam3FeaturesIcons-07_fcad574f-17cc-43df-9a38-b5f60fe0706b.webp?v=1718265324)
Video Output/Streaming
Picture in Picture
![](https://cdn.shopify.com/s/files/1/0214/9392/files/download_18e123ef-f9ed-4f88-93ee-58fd16acab48.jpg?v=1677661249)
![video-bg](https://cdn.shopify.com/s/files/1/0214/9392/files/video-bg2.png?v=1669972162)
![smartycam icon](https://cdn.shopify.com/s/files/1/0214/9392/files/SmartyCam3FeaturesIcons-01_4521d266-641b-4f02-9cef-a8e064cb04cd.webp?v=1718265325)
![](https://cdn.shopify.com/s/files/1/0214/9392/files/SmartyCamDualRSA3VideoOverlayExample.jpg?v=1666261887)
![smartycam icon](https://cdn.shopify.com/s/files/1/0214/9392/files/SmartyCam3FeaturesIcons-02.webp?v=1718265325)
Standalone Feature
The SmartyCam 3 Dual provides you with a CAN expansion that connects with many Aim devices such as the Solo 2 DL Laptimer, various Aim Dash Display Loggers, and PDM Dash systems. This is a standard practice within our products, however, we have also equipped the SmartyCam 3 Dual with unterminated CAN connections which allow you to connect the camera to any system as a standalone feature. No matter your vehicle and equipment, with the unterminated connectors you can run the Dual through the CAN/ECU connections of your choosing.
![smartycam icon](https://cdn.shopify.com/s/files/1/0214/9392/files/SmartyCam3FeaturesIcons-03.webp?v=1718264337)
Quality
![](https://cdn.shopify.com/s/files/1/0214/9392/files/SC3_No_Wave_Effect_SmartyCam3_1_f28fc1c3-e987-4226-932c-807927a63a5b.jpg?v=1666261908)
![smartycam icon](https://cdn.shopify.com/s/files/1/0214/9392/files/SmartyCam3FeaturesIcons-04.webp?v=1718264337)
Anatomy
![smartycam icon](https://cdn.shopify.com/s/files/1/0214/9392/files/SmartyCam3FeaturesIcons-05.webp?v=1718264337)
Higher Storage Capacity
SD cards sold separately.
![](https://cdn.shopify.com/s/files/1/0214/9392/files/5FE47155-99DA-4C62-A361-22317D8C3857_1_201_a.jpg?v=1666349426)
![smartycam icon](https://cdn.shopify.com/s/files/1/0214/9392/files/SmartyCam3FeaturesIcons-06_818d2c02-7234-4a85-bc35-b6507606bd30.webp?v=1718265325)
![smartycam icon](https://cdn.shopify.com/s/files/1/0214/9392/files/SmartyCam3FeaturesIcons-08_b7506d4f-aa6a-48e4-8d69-f5cf7c917cbc.webp?v=1718265324)
Configure & Analyse with Race Studio ANalysis 3
- CMOS sensor: Global Shutter
- Video Out: 3G-SDI
- External power: 9-15 Volt
- Auto Power ON: Yes
- Auto Power OFF: Yes
- Body: Anodised Aluminium
![smartycam3 dual pinout](https://cdn.shopify.com/s/files/1/0214/9392/files/smartycam3dual_pinout_1024x1024.png?v=1706607987)
- SmartyCam 3 Dual
- External Power Cable
- USB-C Cable
- 2 Bullet Cameras
- 2 Co Ax Cables
- Harness (Optional)
![](https://cdn.shopify.com/s/files/1/0214/9392/files/SC3InfoBreakdownSmartyCam3-01-01_5555363b-389c-4696-a05f-7350dbb6252f.png?v=1696260561)
Picture in Picture
Standalone Feature
Quality
Anatomy
![](https://cdn.shopify.com/s/files/1/0214/9392/files/F51C0B4F-2D44-49C1-AF70-692F6A4E42BE.png?v=1666349139)
Technical Specifications
- Video Out: 3G-SDI
Whats in The Box
- SmartyCam 3 Dual
- USB-C Cable
- 2 Bullet Cameras
- 2 Co Ax Cables
![SmartyCam 3 Dual Motorsport Camera](http://www.aimshop.com/cdn/shop/products/SmartyCam3DualwithBullets_Compressed_1445x.png?v=1669912846)
![SmartyCam 3 Dual Motorsport Camera](http://www.aimshop.com/cdn/shop/products/5FE47155-99DA-4C62-A361-22317D8C3857_1445x.png?v=1669912878)
![SmartyCam 3 Dual Motorsport Camera](http://www.aimshop.com/cdn/shop/products/AF8B4D39-BE34-46DF-B099-F7D51DBB46DD_1445x.png?v=1669912846)
![SmartyCam 3 Dual Motorsport Camera](http://www.aimshop.com/cdn/shop/products/0B1E8588-CA73-4096-A0F4-78D61DF3F635_1445x.png?v=1669912846)
![SmartyCam 3 Dual Motorsport Camera](http://www.aimshop.com/cdn/shop/products/2C8CB2F6-9744-4FB1-8E31-2486AF67E1A5_1445x.png?v=1669912846)
![SmartyCam 3 Dual Motorsport Camera](http://www.aimshop.com/cdn/shop/products/5E6CACA4-159A-4E95-91E2-539C5BB471AB_1445x.png?v=1669912846)
