M-Sport Ford Fiesta Rally 2 Aim SmartyCam 3 Corsa Kit - MK2 from 2022
SKU: FORD-SM3
- Regulärer Preis
- £1,150.00
- Regulärer Preis
- Verkaufspreis
- £1,150.00
- Stückpreis
- pro
Compact, Advanced, Precise
Enhance your M-Sport Ford Fiesta Rally 2's performance with the AiM SmartyCam 3 Corsa Kit, specifically designed for Mk2 models from 2022.
Supported Models and years
M-Sport Ford Fiesta Rally 2 Mk2from 2022
If specifically set by M-Sport, these models feature a CAN data bus accessible to AiM devices through a Deutsch DTM06-2S connector located by/behind the co-driver’s foot plate, labelled CAN3.
Standalone Feature
The SmartyCam 3 Corsa provides you with a CAN expansion that connects with many Aim devices such as the Solo 2 DL Laptimer, various Aim Dash Display Loggers, and PDM Dash systems. This is a standard practice within our products, however we have also equipped the SmartyCam 3 Corsa with unterminated CAN connections which allow you to connect the camera to any system as a standalone feature. No matter your vehicle and equipment, with the unterminated connectors you can run the Corsa through your CAN/ECU connections.
Quality
Anatomy
Finished with a sleek new look, the SmartyCam 3 Corsa is assured to add efficiency, informational data, productivity, and style to your racing. AiM SmartyCam 3 Corsa allows you to connect ECU direct to your camera with b connectors. Here at AiM, we provide only the best innovations and are constantly and consistently working to better your racing experience.
Higher Storage Capacity
SD cards sold separately.
Standalone Feature
Quality
Anatomy
Technical Specifications
- CMOS sensor: Global Shutter
- Field of view: 67°, 84°
- External power: 9-15 Volt
- Connectors: 3 Binder 712 female 1 USB-C
- Auto Power ON: Yes
- Auto Power OFF: Yes
- Dimensions: 102.2 x 63 x 46.5 mm
- Weight: 280g, battery included
- Waterproof: IP65-rated to withstand the rigours of motorsport, this kit offers durability and reliability for M-Sport Ford Fiesta Rally 2 drivers
M-Sport Ford 22 Protocol
Channels received by AiM devices configured with M-Sport Ford 22 protocol are:
Channel Name | Function |
RPM | RPM |
Vehicle Speed | Vehicle speed |
Gear FIA | Engaged gear |
Steering Wheel | Steering wheel angle position |
Pedal Pos | Throttle pedal position |
Brake Press Fr | Front brake pressure |
Brake Press Rr | Rear brake pressure |
Turbo Speed | Turbo speed |
Engine Cool Temp | Engine coolant temperature |
Engine Oil Temp | Engine oil temperature |
Air Charge Temp | Air charge temperature |
Exhaust Temp | Exhaust gas temperature |
Oil Pressure | Oil pressure |
MAP | Manifold air pressure |
ALS Cal | Anti lag system calibration |
- SmartyCam 3 Corsa
- USB-C Cable
2m CAN Cable
- 712 5 Pin Male
