Link Mitsubishi EVOLink (IV-VIII) - EVO8X PlugIn ECU
SKU: EVO8X
- Regulärer Preis
- £1,325.00
- Regulärer Preis
- Verkaufspreis
- £1,325.00
- Stückpreis
- pro
This ECU is designed for the EVO 4-8 4G63 engine.
Includes onboard 4 bar or 7 bar MAP sensor
Suitable Applications:
CN9A Lancer Evolution 4
CP9A Lancer Evolution 5, 6 & 6.5 (TME)
CT9A Lancer Evolution 7
CT9A Lancer Evolution 8 (models with 4-plug ECU only)
*Some EVO 8’s have a 3 plug ECU. These applications will need the EVO9X Link ECU
Sequential fuel delivery
OEM idle hardware supported
CAN port
USB tuning cable included
Staged injection
Knock with "windowing"
I/O Expansion Options:
The Mitsubishi Lancer Evolution IV - VIII plug-in ECU has two expansion connectors.
Expansion connector 1:
Gnd Sensor Ground Only
DI 7 Digital input
DI 8 Digital input
DI 9 Digital input
Aux 4 Auxiliary Output
Expansion connector 2
Aux 9 EThrottle - can't be used as an Aux Out
Aux 10 Auxiliary Output
An Volt 6 Analog 0-5V input
An Volt 7 Analog 0-5V input
An Volt 9 Analog 0-5V input
An Volt 10 Analog 0-5V input
- G4X PlugIn ECU
- Stickers
![](https://cdn.shopify.com/s/files/1/0214/9392/files/Link_Banner_Description.png?v=1616071775)
CN9A Lancer Evolution 4CP9A Lancer Evolution 5, 6 & 6.5 (TME)
CAN port
Staged injection
The following expansion connector inputs/outputs are provided:The Mitsubishi Lancer Evolution IV - VIII plug-in ECU has two expansion connectors.
DI 7 Digital input
DI 8 Digital input
DI 9 Digital input
- G4X PlugIn ECU
- Stickers
![Link Mitsubishi EVOLink (IV-VIII) - EVO8X PlugIn ECU - AimShop.com](http://www.aimshop.com/cdn/shop/products/LinkEVOLink_IV-VIII_-EVO8X_1445x.png?v=1614347974)
![Link Mitsubishi EVOLink (IV-VIII) - EVO8X PlugIn ECU - AimShop.com](http://www.aimshop.com/cdn/shop/products/LinkMitsubishiEVOLink_IV-VIII_-EVO8XPlugInECU2_1445x.png?v=1616433638)
