Tyre Pressure Monitoring System with Solo 2 DL
SKU: SOLO2-K3-TPMS-KIT-X47SOLO2DL02
- Regulärer Preis
- £920.00
- Regulärer Preis
- Verkaufspreis
- £920.00
- Stückpreis
- pro
Tyre Pressure Monitoring System with Solo2 DL
Tyre Pressure Monitoring System & Solo2 DL to get the most precise lap times.
Key Features:
The Solo2 DL with ECU ConnectionConnecting to over a 1,000+ ECUs, we are sure it will work for you. You can connect your Solo2 DL to the ECU, with a simple ODB11 plug or hardwired in, to providing you with all your car's information and power with just one cable. |
Solo2 DL now also features a digital input, allowing you to log RPM either from square wave signals (8-50V each signal) or a pulse signals (150-450v) ignition coil trigger-primary circuit. |
Powering on requires only a few seconds and lap times are calculated with a max 2/100 sec of tolerance. Solo2 DL gives instant Speed, Timing, Splits live data and predictive lap times.
The AiM Solo2 DL has 10 configurable RGB LEDs, and will give you a clear and fast indication of the comparison with your last lap. Predictive page: shows the predicted current lap time in the format you set. +/- in relation to the Reference Lap Predicted Lap Time You can custom build the layout of the display, to show the information you choose on 4 reconfigurable pages, your data shown in your way, see an example below. |
Solo2 DL Data Recall Modes
The perfect connection to get all your data from the ECU, merge them with the GPS information and transmit everything to the SmartyCam HD then watch the graphical overlay in the video.
Wi-Fi Communication with the PC
Simply put if there is no track already the Solo2 DL will create a new one... |
With over 4000 tracks pre-loaded from around the world. As soon as its switched on the Solo2 DL identifies its position then once you start to drive it automatically recognises the start line coordinates of the track and will start sampling lap times, every time you go past. |
If the tracks not loaded in the database Solo 2 DL will switch to learning mode automatically and will understand the characteristics of the track and give you your lap time. |
Each sensor is labelled FR, FL, RR, RL for each of the wheels of the car. Extra wheels can be clone coded that can then be used as sets of spares for pit changes.
The wire colour codes are: +12V - Red |
Not Enough |
You can add a Handheld Reader / Programmer. The handheld reader can read each wheel individually, It reads by close proximity whereas the CAN receiver uses a radio link to the sensors with the address of each sensor pre-defined as to which wheel is being measured.
TPMS Connections
The AiM Tyre Pressure Monitoring System can be used with all of our dash display loggers (except Solo2). You can add a 4x CAN connection multiplier and a GPS module or our SmartyCam cameras to your system. See diagram below: |
Unlock your potential
- Display: Graphical
- Display Resolution: 238x99 pixels
- Back Light: 7 configurable RGB colours
- Shift Lights/alarm LEDs: 10 configurable RGB LEDs
- Integrated Track Database: Yes
- Inertial Platform: Internal 3 axis ±5G accelerometer + 3 axis gyro + 3 axis magnetometer
- Wi-Fi Connection: Yes
- GPS: 10 Hz External power: 12 V
- Memory: 4 GB
- Battery Type: Rechargeable Lithium
- Dimensions: 98.0x73.7x30.2 mm
- Weight: 240 g, battery included
- ECU Connection: CAN,RS232 or K-Line to 1,000 + industry leading ECUs
- Multiple Configuration Management: Yes
Sensor
- Range: 0.8000mbar
- Modulation Mode: FSK
- Temperature Measurement Range: -40° - 125°
- Temperature Resolution: 1°
- Sealing: IP67
- Battery Lifespan: Equal to 2 race seasons
- RF Frequency: 433MHz
- High Power Emission Power: <8dbm
CAN bus Receiver
- Baud Rate: 1000kbps
- DC: 12V-24V
- Pressure accuracy +/-20 mbar
- Connection output for CAN 2.0 1Mbps 11 bit
- Aim Solo 2 DL
- Power Cable with AC adapter
- Mounting Bracket with screws
- Aim Sticker
TPMS
- 1 - CAN Receiver
- 1 - Wiring Harness
- 4, 8, 12 - Wheel Sensors depending on what you want
Key Features:
The AiM tyre pressure monitoring system kit comes with a wiring harness four, eight or twelve sensors and a CAN receiver which is compatible for race car applications and competitions. The receiver utilises 1Mbit CAN (11bit) which has become the standard over the years for most professional ECUs, data loggers and dashboards within the motorsport and automotive sectors. |
Each sensor is labelled FR, FL, RR, RL for each of the wheels of the car. Extra wheels can be clone coded that can then be used as sets of spares for pit changes. The wire colour codes are: +12V - Red |
Not Enough |
You can add a Handheld Reader / Programmer. The handheld reader can read each wheel individually, It reads by close proximity whereas the CAN receiver uses a radio link to the sensors with the address of each sensor pre-defined as to which wheel is being measured. |
TPMS Connections
Technical Specifications
- Memory: 4 GB
Sensor
- Range: 0.8000mbar
- Sealing: IP67
CAN bus Receiver
- DC: 12V-24V
Whats in The Box
- Aim Solo 2 DL
- Aim Sticker
TPMS
- 1 - CAN Receiver
