AiM SmartyCam HD 2.1 & SmartyCam 3 Mini Roll Cage Mount Motorcycle
SKU: SM-VB-S
- Regulärer Preis
- £50.00
- Regulärer Preis
- Verkaufspreis
- £50.00
- Stückpreis
- pro
The SmartyCam can be installed using the roll cage mount. It is suitable for SmartyCam HD 2.1 & SmartyCam 3.
Fits the SmartyCam HD camera | Universal roll bar fitment |
Standard or extended length | For SmartyCam HD 2.1 & SmartyCam 3 |
The AiM mini roll bar mounts have been designed to fit the SmartyCam camera, and enable it to easily be mounted to a roll bar tube.
The mount is manufactured from aluminium with a black anodised finish and designed to withstand the rigours of motorsport use.
Provides an easy method of mounting the SmartyCam to a roll bar.
The supplied jubilee drive clips allow for fitting two different roll cage tube diameters.
Standard or extended lengths are available to choose from.
- Roll cage mount (standard or extended version) One supplied
- 2 x Jubilee clips
The SmartyCam can be installed using the roll cage mount. It is suitable for SmartyCam HD 2.1 & SmartyCam 3.Key Features :
The AiM mini roll bar mounts have been designed to fit the SmartyCam camera, and enable it to easily be mounted to a roll bar tube.The mount is manufactured from aluminium with a black anodised finish and designed to withstand the rigours of motorsport use.
Provides an easy method of mounting the SmartyCam to a roll bar.The supplied jubilee drive clips allow for fitting two different roll cage tube diameters.
- 2 x Jubilee clips
