AiM PDM08 / PDM32 10" Dash Mount
SKU: Display-10-M
- Regulärer Preis
- £30.00
- Regulärer Preis
- Verkaufspreis
- £30.00
- Stückpreis
- pro
PDM08 / PDM32 Dash Mount
AiM PDM08 / PDM32 10" Dash Mount Modular Steering Assembly.
Due to the size of the dash, this bracket will probably be used with our single mount centre hub on the steering column or our chassis weld-on and bolt-on tabs, it will also work without steering wheel mounts if you prefer. Optional Weld on the tab for your chassis or steering column. |
Made from stainless steel with a raw finish it has interchangeable components to facilitate the mounting of displays, buttons, dash, lap timers and shift lights. |
Unlock your potential |
- Stainless Steel
- 2mm Thick
- AiM PDM08 / PDM32 10" Dash Mount
- Stainless Steel
- 2mm Thick
Whats In The Box
