AiM MX2E Plug & Play Dash Logger + SmartyCam Corsa for Lotus Elise / Exige Track Day Kit
SKU: MX2E-SM-CAM-HD-2-MX2E-AH-CAN-M-40-SM-VB-S
- Regulärer Preis
- £2,715.00
- Regulärer Preis
- Verkaufspreis
- £2,715.00
- Stückpreis
- pro
Ultimate Track Day Kit for Lotus Elise/Exige
Integrated LEDs
Data Hub
SmartyCam Corsa
The video format is at H.264 1920x1080 pixels, 60 FPS, and the display resolution of 128x128 pixels gives your footage crisp condition. Our quality doesn’t falter, even under the pressure of extreme motorsport conditions such as poor weather, strong vibrations, continuous rain, and high/low temperatures as extreme as -10°C to + 50°C. Our camera is also waterproof (IP65) for extra protection.
Automatic Start/Stop
The SmartyCam 3 Corsa can be switched on by the logger it is connected to. Switch-off is automatic too, you decide after what period of non-activity the camera will switch off.
AiM MX2E Plug & Play Dash Logger + SmartyCam 3 Corsa for Lotus Elise / Exige Track Day Kit
- Display : 6" TFT
- Contrast: 600: 1
- Ambient Light Sensor: Yes
- Integrated buttons in cluster: 4
- Status information LEDs: 6
- Shift light LEDs: 10
- Turn indicators: 2
- CAN connections: 2
- ECU connection: Yes
- External modules: GPS Module, Channel Expansion, Lambda Controller, SmartyCam HD
- Rear camera input: Yes
- Internal memory: 4GB
- Body: Anodised Aluminium
- Connectors: 1 Delphi 12040722 connector & 4 binder 712 connectors
- Dimensions: 191 x 114,2 x 26,4 mm
- Weight: 640g
- Power consumption: 400 mA
- Adapter Harness: Elise/Exige model years 2004-2007 (version with airbag only)
- SmartyCam 3 Corsa
- CMOS sensor: Global Shutter
- Video Out: 3G-SDI
- External power: 9-15 Volt
- Auto Power ON: Yes
- Auto Power OFF: Yes
AiM MX2E Plug & Play Dash Logger Kit for Lotus Elise / Exige
- MX2E Dash Logger
- Cluster
- GPS Module
- Screws & Washers
- Adapter Harness (optional if required)
- Data Hub
- Mini Roll Cage Mount
- SmartyCam 3 Corsa
- CAN Cable 2m
- Battery Charger
- USB/AC power adapter
- Software installation CD
- User Manual
- AiM sticker
Integrated LEDs
Data Hub
SmartyCam Corsa
- Display : 6" TFT
- Contrast: 600: 1
- Weight: 640g
- SmartyCam 3 Corsa
- Video Out: 3G-SDI
- MX2E Dash Logger
- Cluster
- GPS Module
- Screws & Washers
- Data Hub
- SmartyCam 3 Corsa
- CAN Cable 2m
- Battery Charger
- User Manual
- AiM sticker
MX2E | MX2E Technical | Installation Guide | Adapter Harness |
SmartyCam Corsa | SmartyCam Corsa Technical | Data Hub | Race Studio 3 |
