AiM ECU Log Racing Datalogger
SKU: ECU-L
- Regulärer Preis
- £375.00
- Regulärer Preis
- Verkaufspreis
- £375.00
- Stückpreis
- pro
+ MwSt. (nur Großbritannien)
ECU Log
Compact, powerful, reliable
ECU Log is the smallest datalogger to record data from your ECU. Its dimensions are only 61 x 44 x 27mm.
The reduced size of the ECU Log makes it ideal for motorcycle and any underseat compartment installation. The analysis of the performance is a key factor, all recorded data can be managed in Race Studio 3 Analysis with histograms, scatters, diagrams, maps and even videos recorded with a SmartyCam are automatically synchronized to the laps data for a better comparison.
![ECU Log](https://cdn.shopify.com/s/files/1/0214/9392/files/image1.png?v=1712160190)
It records data coming from:
- ECU stream CAN: K-line or RS232 connections
- Expansions:
- GPS09c: GPS module
- ACC 2: Analog inputs
- LCU-One S: Lambda controller
- SmartCam 3 series: Motorsport cameras
Then, it features:
- ECU connection
- 4 GB internal memory
- Removable USB Type-C key
- Waterproof (IP65)
![ECU Log](https://cdn.shopify.com/s/files/1/0214/9392/files/eculogscreen.png?v=1712216034)
A flexible system
It is simple to create a complete system with the new ECU Log designed by AiM. Different expansions are available to cover most requirements.
![ECU Log](https://cdn.shopify.com/s/files/1/0214/9392/files/exp.png?v=1712217145)
![ECU Log](https://cdn.shopify.com/s/files/1/0214/9392/files/coneg.png?v=1712217687)
- ECU Connection: CAN, RS232 or K-Line to 1,000+ industry leading ECUs
- External Modules Connection: GPS09c/GPS09c Pro, ACC2, LCU1, SmartyCam 3 Series
- External power: 9÷15 V
- Internal Memory: 4GB + removable USB-C memory card
- Connectors: 1socket (Binder) 712, 5 pins, 1socket (Binder) 712, 7 pins, 1 USB Type-C
- Material: PA6 GS30%
- Dimensions: 61.4 x 44.7x27.2 mm
- Weight: 100g approx
- ECU Log
- Mini USB drive 16gb
- Either CAN/OBDII or CAN/RS232/EXT. Power 2m cable
- USB 2.0 A-Type C-Type 2m cable
ECU Log
- Expansions:
- ECU connection
- Waterproof (IP65)
A flexible system
It is simple to create a complete system with the new ECU Log designed by AiM. Different expansions are available to cover most requirements.![ECU Log](https://cdn.shopify.com/s/files/1/0214/9392/files/exp.png?v=1712217145)
![](https://cdn.shopify.com/s/files/1/0214/9392/files/Free_Download.png?v=1629297377)
With Race Studio 3 you can also analyse all data recorded by EVO4S and downloaded to your PC: graphs, histograms and tables will help you study your performance, providing an objective support to avoid mistakes and improve performance. ![]() |
- ECU Log
![AiM ECU Log Racing Datalogger - AimShop.com](http://www.aimshop.com/cdn/shop/files/image1_1445x.png?v=1712160190)
![AiM ECU Log Racing Datalogger - AimShop.com](http://www.aimshop.com/cdn/shop/files/image2_1445x.png?v=1712160191)
![AiM ECU Log Racing Datalogger - AimShop.com](http://www.aimshop.com/cdn/shop/files/opt1_1445x.png?v=1712217891)
![AiM ECU Log Racing Datalogger - AimShop.com](http://www.aimshop.com/cdn/shop/files/opt2_1445x.png?v=1712217891)
