Yamaha YZF-R1/R1M & YZF-R6 AiM Solo 2 DL Plug & Play Cable
SKU: YAM-1-PP
- Normal pris
- £67.00
- Normal pris
- Udsalgspris
- £67.00
- Pris per stk
- om
The AiM ECU plug & play cable has been specifically designed for Yamaha bikes. Allowing easy installation to a Solo 2 DL. With a 7-pin 712 male binder connection.
Yamaha plug & play cable | 7 pin - 712 male binder connection |
Receive data | Suitable for Solo 2 DL |
Yamaha Plug & Play ECU Cable
The AiM ECU plug & play cable has been specifically designed for the Yamaha bike. This plug & play cable can be used for the Solo 2 DL.
Yamaha YZF-R1 - From 2015 | Yamaha YZF-R1M - From 2015 |
Yamaha YZF-R6 - From 2017 |
Example data protocols
- Below is a pinout drawing for the Yamaha YZF-R1/R1M & YZF-R6 Solo 2 DL plug & play connection cable
- Yamaha YZF-R1/R1M & YZF-R6 Solo 2 DL Plug & Play connection cable
The AiM ECU plug & play cable has been specifically designed for Yamaha bikes. Allowing easy installation to a Solo 2 DL. With a 7-pin 712 male binder connection.Key Features :
The AiM ECU plug & play cable has been specifically designed for the Yamaha bike. This plug & play cable can be used for the Solo 2 DL.The cable is an easy fitment to your bike and allows ECU data to be logged.
The plug & play cable currently fits the following Yamaha bike models:Yamaha YZF-R1 - From 2015 | Yamaha YZF-R1M - From 2015 |
