Gå til produktinformation
1 af 1
Super B Nomia 12V340AH Lithium Traction Battery
SKU: SB-E-340
Normal pris
£3,185.00
Normal pris
Udsalgspris
£3,185.00
superb lithium batteries
Super B The Nomia 12V340Ah is a Lithium Iron Phosphate battery (LiFePO4) with a rated capacity of 340Ah. The unique combination of state-of-the art technology and smart software makes this lithium battery a robust, safe and easy to use energy storage solution. Compared to conventional lead-acid batteries, the Super B Nomia 12V340Ah lithium battery offers an enormous weight and space saving. It is very efficient, has extremely high performances and is maintenance free.
  • Product Features
  • Traction battery
  • Lithium Iron Phosphate (LiFePO4): Safe Li-ion technology
  • Integrated BMS (Battery Management System), external disconnect device needed
  • Glass fiber reinforced plastic (GRFP) Casing, Aluminum / PE sandwich side panels
  • Terminals for 2 x M8 bolts
  • Integrated fuse, 32V / 500A
  • Wired communication interface: CANopen
  • Battery monitoring / History Storage
  • Adaptive cell balancing
  • Configurable in serial or parallel connection
  • Output for bistable relay / latching relay
Intended Use
The Nomia 12V210Ah/12V340Ah Li-ion battery serves as a energy source of 12V in power systems for recreational vehicles, commercial vehicles, leisure boats, commercial vessels and stationary applications. Potential applications of this Li-ion battery include: off grid power supply, marine power supply, medium for (renewable) energy storage and (traction) battery for vehicles.Use as a starter battery is not possible. Up to 4 batteries can be connected in series or in parallel to increase the total capacity up to 840Ah or 1360Ah. For more batteries in series or parallel always consult with Super B.
PERFORMANCE
Low maintenance
Fast charging
Safest lithium technology
High discharge currents
High capacity
Low weight
High cycle count
Low self-discharge
CERTIFICATIONS
UN38.3 UN38.3 UN38.3 UN38.3 UN38.3
3 Year Warranty
A 3-year warranty offers the best peace of mind. It is the benefit of years of continuous engineering improvement and proven experience with all of our batteries in the harshest environments.
3 year warranty
The Super B Nomia 12v340ah Lithium Traction Battery is a cutting-edge energy solution designed for a wide range of applications. From electric vehicles to renewable energy storage systems, this lithium-ion battery offers exceptional performance and reliability. With a capacity of 340 amp-hours and a nominal voltage of 12 volts, the Super B Nomia battery provides ample power for demanding tasks.
One of the key advantages of the Super B Nomia battery is its long cycle life. With a lifespan of over 5000 cycles, this battery can withstand years of continuous use without any decline in performance. This makes it an ideal choice for applications that require frequent charging and discharging, such as electric forklifts, golf carts, and marine vessels.
In addition to its high cycle life, the Super B Nomia battery also offers fast charging capabilities. With a charging time of just a few hours, this battery can be quickly replenished and put back into operation. This not only reduces downtime but also increases efficiency, making it an ideal choice for businesses looking to maximise their productivity.
ELECTRICAL SPECIFICATIONS
Nominal capacity
340Ah
Open circuit voltage
13.2v
self-discharge
<3% per month
Cycle Life
>4000 4000 cycles (100% DoD)
Voltage
12v
MECHANICAL SPECIFICATIONS
Dimensions (LxWxH)
417 x 227 x 314 mm / 16.4” x 8.9” x 12.4”
Weight
33 kg / 72.7 lbs
Case material
GFRP
Ingress protection
IP50
Cell type / Chemistry
Prismatic - LiFePO4
Charge method
CCCV
Charge voltage
14.2V
Max. charge current
300A
End of discharge voltag
10V
Discharge current continuous
300A
Discharge pulse current
900 A (30 sec)
TEMPERATURE SPECIFICATIONS
Charge temperature
0°C to 60°C / 32°F to 140°F
Discharge temperature
-10°C to 60°C / 14°F to 140°F
Storage temperature
-20°C to 45°C / -4°F to 113°F
COMPLIANCE SPECIFICATIONS
Certifications
CE, UKCA, FCC, UN 38.3, EN/IEC 62619-62620 (ESTRIN), UN ECE R10.06, UL 1642 (Cells)
Shipping classification
UN 3480
GENERAL SPECIFICATIONS
EAN-13
8718531362314
Battery designation
IFpP/41/173/205/ [2P4S]M/-10+60/95
Available to download Here
superb app
  • Product Features
  • Traction battery
Intended Use
PERFORMANCE
Low maintenance
Fast charging
High capacity
Low weight
High cycle count
Low self-discharge
CERTIFICATIONS
3 Year Warranty
3 year warranty
Specifications
Nominal capacity
340Ah
13.2v
self-discharge
<3% per month
Cycle Life
Voltage
12v
Dimensions (LxWxH)
Weight
33 kg / 72.7 lbs
Case material
GFRP
Ingress protection
IP50
Prismatic - LiFePO4
Charge method
CCCV
Charge voltage
14.2V
Max. charge current
300A
10V
300A
900 A (30 sec)
Charge temperature
Storage temperature
Certifications
UN 3480
EAN-13
8718531362314
Battery designation
Quickstart Guide
Mobile App
superb app
