SmartyCam 3 Corsa
SKU: SM3
- Normal pris
- £1,150.00
- Normal pris
- Udsalgspris
- £1,150.00
- Pris per stk
- om
Compact, Advanced, Precise
The SmartyCam 3 Corsa: The Ultimate Motorsports Camera. Engineered to deliver unparalleled video performance, with GPS and ECU data for complete and comprehensive information.
Video format is at H.264 1920x1080 pixels, 60 FPS, and the display resolution of 128x128 pixels gives your footage crisp condition. Our quality doesn’t falter, even under the pressure of extreme motorsport conditions such as poor weather, strong vibrations, continuous rain, and high/low temperatures as extreme as -10°C to + 50°C. Our camera is also waterproof (IP65) for extra protection. With the built-in data logger experience enhanced RPM, throttle, engaged gears, acceleration, temperatures, and pressures including a tri-axis accelerometer measuring 16G.
Standalone Feature
The SmartyCam 3 Corsa provides you with a CAN expansion that connects with many Aim devices such as the Solo 2 DL Laptimer, various Aim Dash Display Loggers, and PDM Dash systems. This is a standard practice within our products, however we have also equipped the SmartyCam 3 Corsa with unterminated CAN connections which allow you to connect the camera to any system as a standalone feature. No matter your vehicle and equipment, with the unterminated connectors you can run the Corsa through your CAN/ECU connections.
Quality
Anatomy
Finished with a sleek new look, the SmartyCam 3 Corsa is assured to add efficiency, informational data, productivity, and style to your racing. AiM SmartyCam 3 Corsa allows you to connect ECU direct to your camera with b connectors. Here at AiM, we provide only the best innovations and are constantly and consistently working to better your racing experience.
Higher Storage Capacity
SD cards sold separately.
- CMOS sensor: Global Shutter
- Field of view: 67°, 84°
- External power: 9-15 Volt
- Connectors: 3 Binder 712 female 1 USB-C
- Auto Power ON: Yes
- Auto Power OFF: Yes
- Dimensions: 102.2 x 63 x 46.5 mm
- Weight: 280g, battery included
- SmartyCam 3 Corsa
- USB-C Cable
- 712 5 Pin Male
- 2 or 4 Metre Patch Cable
Standalone Feature
Quality
Anatomy
Technical Specifications
Whats in The Box
- SmartyCam 3 Corsa
- USB-C Cable
- 712 5 Pin Male
