Gå til produktinformation
1 af 1
SDI to BNC Adaptor
SKU: SDI-to-BNC
Normal pris
£15.00
Normal pris
Udsalgspris
£15.00
This adaptor converts the SDI output connector of a SmartyCam 3 GP HD or SmartyCam3 Dual into A BNC female connector. This makes it easy to connect to industry standard connections of live streaming video equipment.
We can also make a BNC cable if required at your desired length.
Characteristics Impedance 50 Ω
Dielectric withstand voltage 2500V RMS,50Hz,at sea level
Dielectric Resistance
5000MΩ
Connector Type SMA Male – BNC Female
Durability Mating Cycle
500
Electrial & Mechanical Specs.
Material and Plating
Body Brass / Nickel plating
`Insulator PTFE
Center Contact (pin) Beryllium , Brass / Gold platin
5000MΩ
500
`Insulator PTFE
