Skoda Fabia R5 Aim SmartyCam 3 Corsa Kit - R5 2015 to 2018 - R5 EVO2 from 2019
SKU: skoda-SM3
- Normal pris
- £1,150.00
- Normal pris
- Udsalgspris
- £1,150.00
- Pris per stk
- om
Compact, Advanced, Precise
Enhance your Skoda Fabia R5's performance with the AiM SmartyCam 3 Corsa Kit, specifically designed for models from 2015 to 2018 and the EVO2 from 2019.
Supported Models and years
Skoda Fabia R52015 - 2018
Skoda Fabia R5 EVO2from 2019
These models feature a loom extension supplied by the car manufacturer which has a DTM 4 pin connector on one end carrying CAN and power supply contacts.
Standalone Feature
The SmartyCam 3 Corsa provides you with a CAN expansion that connects with many Aim devices such as the Solo 2 DL Laptimer, various Aim Dash Display Loggers, and PDM Dash systems. This is a standard practice within our products, however we have also equipped the SmartyCam 3 Corsa with unterminated CAN connections which allow you to connect the camera to any system as a standalone feature. No matter your vehicle and equipment, with the unterminated connectors you can run the Corsa through your CAN/ECU connections.
Quality
Anatomy
Finished with a sleek new look, the SmartyCam 3 Corsa is assured to add efficiency, informational data, productivity, and style to your racing. AiM SmartyCam 3 Corsa allows you to connect ECU directly to your camera with b connectors. Here at AiM, we provide only the best innovations and are constantly and consistently working to better your racing experience.
Higher Storage Capacity
SD cards sold separately.
- CMOS sensor: Global Shutter
- Field of view: 67°, 84°
- External power: 9-15 Volt
- Connectors: 3 Binder 712 female 1 USB-C
- Auto Power ON: Yes
- Auto Power OFF: Yes
- Dimensions: 102.2 x 63 x 46.5 mm
- Weight: 280g, battery included
- Waterproof: IP65-rated to withstand the rigours of motorsport, this kit offers durability and reliability for Skoda Fabia R5 drivers
Channels received by AiM devices configured with Skoda Fabia R5 protocol are:
Channel Name | Function |
RPM | Engine speed |
Gear | Selected gear |
Car Speed | Vehicle speed |
AccelPedal | Pedal accelerator ratio |
FrontBrkPress | Front brake pressure |
pHandBrake | Handbrake pressure |
SteeringPos | Steering position Angle |
TripDist2 | Trip distance 2 |
GDUOutLed | GDU output led |
StRoadMode | Status road mode (=1) - Special stage (=0) |
- SmartyCam 3 Corsa
- USB-C Cable
2m CAN Cable
- 712 5 Pin Male
Standalone Feature
Quality
Anatomy
Technical Specifications
Skoda Fabia R5 Protocol
What's In The Box
- SmartyCam 3 Corsa
- USB-C Cable
2m CAN Cable
- 712 5 Pin Male
