Link BMW Link - E36X PlugIn ECU
SKU: E36X
- Normal pris
- £975.00
- Normal pris
- Udsalgspris
- £975.00
- Pris per stk
- om
Link BMW Link - E36X ECU PlugIn ECU
This ECU is designed for the E36 M50TUB25 engine.
This ECU only works with the Engine Code M50TUB25 (Bosch ECU from the factory).
Works with manual & automatic transmissions.
Built-in 4 Bar MAP sensor or 7 Bar MAP sensor included.
Suitable Applications:
M50TUB25 engine with the Bosch M3.3.1 ECU from factory
Sequential fuel delivery
OEM idle hardware supported
CAN port
USB tuning cable included
Staged injection
Knock with "windowing"
Expansion connector - The following expansion connector inputs/outputs are provided:
TEMP3 Temperature sensor input
TEMP4 Temperature sensor input
VOLT4 Analog 0-5V input
VOLT5 Analog 0-5V input
DI8 Digital Input
DI7 Digital Input
+5V Low Current +5V Supply
GND Sensor Ground Only
*Please see the PC Link Help file for details regarding installing the Expansion Cable.
- G4X PlugIn ECU
- Stickers
M50TUB25 engine with the Bosch M3.3.1 ECU from factoryG4X PlugIn Key Features (where applicable):
CAN port
Staged injection
TEMP3 Temperature sensor inputTEMP4 Temperature sensor input
DI8 Digital Input
DI7 Digital Input
- G4X PlugIn ECU
- Stickers
