Link Subaru WRXLink - WRX2X PlugIn ECU
SKU: WRX2X
- Normal pris
- £850.00
- Normal pris
- Udsalgspris
- £850.00
- Pris per stk
- om
Designed for the WRX V1-2 EJ20.
Air temp sensor highly recommended.
Suitable Applications:
GC8A
GC8B
GC8C
WRX and STI from 10/1992 to 8/1996
PlugIn Key Features:
Sequential fuel delivery
OEM idle hardware supported
CAN port
USB tuning cable included
Staged injection
Knock with "windowing"
I/O Expansion Options:
Expansion connector 1
Gnd Sensor Ground Only
+5V Low Current +5V Supply
DI 5 Digital Input
DI 6 Digital Input
Volt 5 Analog 0-5V input
Volt 6 Analog 0-5V input
An Temp 2 Temperature sensor input
Expansion connector 2
DI 9 Digital Input
DI 10 Digital Input
Volt 8 Analog 0-5V input
Volt 9 Analog 0-5V input
- G4X PlugIn ECU
- Stickers
GC8AGC8B
GC8C
CAN port
Staged injection
The following expansion connector inputs/outputs are provided:Expansion connector 1
DI 5 Digital Input
DI 6 Digital Input
DI 9 Digital Input
DI 10 Digital Input
- G4X PlugIn ECU
- Stickers
