Link Subaru WRXLink (7-9) WRX9X PlugIn ECU
SKU: WRX9X
- Normal pris
- £1,325.00
- Normal pris
- Udsalgspris
- £1,325.00
- Pris per stk
- om
Designed for the WRX V7-9 EJ20.
This ECU fits 5 Plug ECUs.
Air temp sensor highly recommended.
Suitable Applications:
Designed for the WRX V7-9 EJ20 (GD/GG chassis, MY2000-2007 with cam control, 2.0L models only)
PlugIn Key Features:
Sequential fuel delivery
OEM idle hardware supported
CAN port
USB tuning cable included
Staged injection
Knock with "windowing"
I/O Expansion Options:
Expansion connector 1
DI 7 Digital Input
DI 8 Digital Input
DI 9 Digital Input
An Volt 11 Analog 0-5V input
Expansion connector 2
Gnd Sensor Ground Only
Aux 9 EThrottle - can't be used as an Aux out
Aux 10 Auxiliary Output
Volt 6 Analog 0-5V input
Volt 7 Analog 0-5V input
Volt 9 Analog 0-5V input
Volt 10 Analog 0-5V input
- G4X PlugIn ECU
- Stickers
Designed for the WRX V7-9 EJ20 (GD/GG chassis, MY2000-2007 with cam control, 2.0L models only)PlugIn Key Features:
CAN port
Staged injection
The following expansion connector inputs/outputs are provided:Expansion connector 1
DI 7 Digital Input
DI 8 Digital Input
DI 9 Digital Input
- G4X PlugIn ECU
- Stickers
