Link CAN PCB Cable
SKU: CANPCB
- Normal pris
- £28.00
- Normal pris
- Udsalgspris
- £28.00
- Pris per stk
- om
Link CAN PCB Cable
Cable (CANPCB)
Required to add CAN/Serial communications to G4+/G4X Plugin ECU’s. Plugs directly into ECU PCB header. Use the Link CANF connector (purchased separately) to connect.
Link CAN PCB Cable
- CAN to JST Connector
- 200mm
Link CAN PCB Cable
Cable (CANPCB)Required to add CAN/Serial communications to G4+/G4X Plugin ECU’s. Plugs directly into ECU PCB header. Use the Link CANF connector (purchased separately) to connect.
Link CAN PCB Cable
- 200mm
