Kawasaki MXK10 AiM GPS Sensor Bracket
SKU: MK10-GPS-B
- Normal pris
- £30.00
- Normal pris
- Udsalgspris
- £30.00
- Pris per stk
- om
The AiM Kawasaki motorcycle GPS bracket has been specifically designed to provide a simple and secure mounting solution for the GPS Module.
Kawasaki GPS Module bracket | All necessary mounting hardware |
Suitable for Kawasaki bikes | |
Kawasaki GPS Sensor Bracket
The Kawasaki MXK10 bracket has been designed to provide a simple and secure way for mounting your GPS Module to your bike.
We also have plug & play options available for the Kawasaki bike. The ECU cables are available to fit the Solo 2 DL and EVO4S Data Logger. See below for bike models: (Sold Separately)
Kawasaki Ninja ZX-10R MY2011 - 2001-2015 | Kawasaki Ninja ZX-10R MY2011 Racing Kit - 2011-2015 |
Example data protocols
- Specifically designed Kawasaki bracket to secure the GPS Module to your bike
- 1 Bracket
- 2 screws
The AiM Kawasaki motorcycle GPS bracket has been specifically designed to provide a simple and secure mounting solution for the GPS Module.Key Features :
The Kawasaki MXK10 bracket has been designed to provide a simple and secure way for mounting your GPS Module to your bike.Our brackets are supplied with all the necessary hardware required for fitting to your bike.
We also have plug & play options available for the Kawasaki bike. The ECU cables are available to fit the Solo 2 DL and EVO4S Data Logger. See below for bike models: (Sold Separately)Kawasaki Ninja ZX-10R MY2011 - 2001-2015 | Kawasaki Ninja ZX-10R MY2011 Racing Kit - 2011-2015 |
- 1 Bracket
- 2 screws
