Honda CBR 600RR & 1000RR AiM Solo 2 DL & EVO4S Logger Plug & Play Cable
SKU: HON-PP
- Normal pris
- £67.00
- Normal pris
- Udsalgspris
- £67.00
- Pris per stk
- om
Honda CBR 600RR & 1000RR Solo 2 DL & EVO4S Plug & Play Cable
The AiM ECU plug & play cable has been specifically designed for Honda bikes. Allowing easy installation to a Solo 2 DL and an EVO4S Data Logger. With a 7-pin 712 male binder connection.
Honda plug & play cable | 7 pin - 712 male binder connection |
Receive data | Suitable for Solo 2 DL & EVO4S Data Logger |
Honda Plug & Play ECU Cable
The AiM ECU plug & play cable has been specifically designed for the Honda bikes. This plug & play cable can be used for the Solo 2 DL and the EVO4S Data Logger.
CBR 600RR - 2003-2019 | CBR 600RR HRC with D11 marked ECU - 2013-2015 |
CBR 1000RR - 2004-2016 | CBR 1000RR HRC - 2014-2016 |
Example data protocols
- Below is a pinout drawing for the Honda Solo 2 DL & EVO4S plug & play connection cable
- Honda CBR 600RR, 1000RR Plug & Play connection cable
The AiM ECU plug & play cable has been specifically designed for Honda bikes. Allowing easy installation to a Solo 2 DL and an EVO4S Data Logger. With a 7-pin 712 male binder connection.Key Features :
The AiM ECU plug & play cable has been specifically designed for the Honda bikes. This plug & play cable can be used for the Solo 2 DL and the EVO4S Data Logger.The cable is an easy fitment to your bike and allows ECU data to be logged.
The plug & play cable currently fits the following Honda bike models:CBR 600RR - 2003-2019 | CBR 600RR HRC with D11 marked ECU - 2013-2015 |
