Ducati 848, 1098, 1198 AiM Solo 2 DL Plug & Play Lap Timer Kit
SKU: SOLO2-K-DUC-2
- Normal pris
- £710.00
- Normal pris
- Udsalgspris
- £710.00
- Pris per stk
- om
+ moms (kun Storbritannien)
AiM Solo 2 DL is the most precise and simple way to get lap times. Specifically designed for the Ducati this kit will ensure an improvement in your driving performance.
Database with more than 4,000 tracks worldwide | Ducati ECU connection cable |
This kit has been specifically designed for Ducati bikes. The kit comes with a cable and bracket for your bike. Connecting the Solo 2 DL to your Ducati ECU will give you all the engine performance information you need to help improve your driving performance.
The plug & play cable currently fits the following Ducati bike models:
![](https://cdn.shopify.com/s/files/1/0214/9392/files/Ducati_1098_Bike.png?v=1620402552)
848 Base/EVO/EVO Corse - 2007-2013 | 1098 Base/S/S Tricolore/R - 2007-2009 |
1198 Base/S/S Corse/R Corse/SP - 2009-2011 |
The Ducati ECU interface cable provides a plug & play solution for connecting the Solo 2 DL lap timmer to your bike. Please refer to the technical sheet on how to connect the ECU cable to your bike.
Data Recall On Screen
- Display: Graphical
- GPS: 10 Hz
- External power: 12 V
- Memory: 4 GB
Below is the pinout drawing for the Ducati 848, 1098, 1198 plug & play connection cable.
- Solo 2 DL
- Power cable with AC adapter
- User manual
- AiM Ducati Connection Cable
- Bracket
- 2 self-locking nuts
AiM Solo 2 DL is the most precise and simple way to get lap times. Specifically designed for the Ducati this kit will ensure an improvement in your driving performance.Key Features :
![](https://cdn.shopify.com/s/files/1/0214/9392/files/AiM_Solo_2_DL_GPS_Lap_Timer_with_ECU_Connection_main_description.png?v=1617010295)
This kit has been specifically designed for Ducati bikes. The kit comes with a cable and bracket for your bike. Connecting the Solo 2 DL to your Ducati ECU will give you all the engine performance information you need to help improve your driving performance.Plug & Play
The plug & play cable currently fits the following Ducati bike models:![](https://cdn.shopify.com/s/files/1/0214/9392/files/Ducati_1098_Bike.png?v=1620402552)
The Ducati ECU interface cable provides a plug & play solution for connecting the Solo 2 DL lap timmer to your bike. Please refer to the technical sheet on how to connect the ECU cable to your bike.The sampled data you record depends on the actual ECU but typically includes RPM, engine load, throttle position (TPS), oil, air, water temperature, oil pressure, battery voltage, speed, gear and lambda value (air/fuel). The list of ECUs is forever growing and being updated.
![](https://cdn.shopify.com/s/files/1/0214/9392/files/Aim_Solo_2_DL_Wifi_Communication_With_PC.png?v=1614779557)
The Solo 2 DL has integrated Wi-Fi, so if you want to review your data in more depth simply transfer your data securely and quickly onto a laptop or computer up to 50m away without the need for connectors and cables. You can then import the data into the Race Studio 3 software.![](https://cdn.shopify.com/s/files/1/0214/9392/files/Yamaha_YZF-R1_2009_-_2014_AiM_Solo_2_DL_Plug_Play_Lap_Timer_Kit_54b3a036-e2b6-4d6e-9ab0-a7c03c0f64b0.png?v=1619781880)
These are some of the items that can be added to our Solo 2 DL for incrementing the performance and data acquired.![](https://cdn.shopify.com/s/files/1/0214/9392/files/Free_Download.png?v=1629297377)
- GPS: 10 Hz
- Memory: 4 GB
- Solo 2 DL
- User manual
- Bracket
![Ducati 848, 1098, 1198 AiM Solo 2 DL Plug & Play Lap Timer Kit - AimShop.com](http://www.aimshop.com/cdn/shop/products/Ducati848_1098_1198AiMSolo2DLPlug_PlayLapTimerKit_1445x.png?v=1619786626)
![Ducati 848, 1098, 1198 AiM Solo 2 DL Plug & Play Lap Timer Kit - AimShop.com](http://www.aimshop.com/cdn/shop/products/Ducati848_1098_1198AiMSolo2DLPlug_PlayLapTimerKit3_1445x.png?v=1619786694)
![Ducati 848, 1098, 1198 AiM Solo 2 DL Plug & Play Lap Timer Kit - AimShop.com](http://www.aimshop.com/cdn/shop/products/Solo2DLRearView_withMagnets_2compressed_47ae4619-48c1-409a-8e65-67a961215eab_1445x.png?v=1641560220)
![Ducati 848, 1098, 1198 AiM Solo 2 DL Plug & Play Lap Timer Kit - AimShop.com](http://www.aimshop.com/cdn/shop/products/Solo2DLBottomCompressed_409af0b5-1e4f-41f3-9e75-5612b8f57287_1445x.jpg?v=1641891569)
