Gå til produktinformation
1 af 4
AiM Brake Pressure Sensor Dash 3 3/8 24 0-160 Bar Motorcycle
SKU: S-P-B-D3-160-X05PSA00160B38-MC
Normal pris
£190.00
Normal pris
Udsalgspris
£190.00
The AiM 3/8th 24 0-160 Bar pressure sensor is suitable for oil and fuel pressure readings and can read pressures up to 160 bars. This sensor will monitor brake pressure levels for optimum performance accurately.
3/8th 24 -  0-160 Bar 4 pins 719 male binder
The AIM 3/8 24 0-160 bar brake pressure sensors are fitted with male four pins black 719 binder plug connections to suit all AIM loggers and dash display/loggers.
  • Supply: 8-16V
  • Characterisation: 500 mV/ 0 bar 4500 mV/ 160 bar
  • Consumption: < 10 mA
  • Sealing: IP66
  • Weight: 30g
  • Cable Length: 400mm
  • Thread: 3/8th 24
  • AiM Brake Pressure Sensor 3/8th 24 - 0-160 Bar
  • Supply: 8-16V
  • Sealing: IP66
  • Weight: 30g
  • Thread: 3/8th 24
