AiM EVO4S Bike Data Logging Kit
SKU: EVO4S-1-APR-PP-SUS-POT-75-SUS-POT-150-P-712-719-10-P-712-719-10-S-P-B-M10-P-712-719-10-V02PCB10BTXG-X05PSA00100B10-V02589090 - X61E4S1301
- Normal pris
- £1,870.00
- Normal pris
- Udsalgspris
- £1,870.00
- Pris per stk
- om
EVO4S Data Logging Kit
AiM EVO4S data logging kit provides you with all the help to improve your performance on the track or road.
Key Features:
The AiM EVO4S Data Logger is a powerful and flexible data logger. It has one connector per channel connection logic and a resigned internal electronic board. The AiM EVO4S is fully compatible with the last generation of AiM dash/logger and our powerful race studio 3 software. |
Many Sensors can be connected to EVO4S via:
Connection Examples
Unlock your potential |
Our mission is to help educate you and enable you to get the most out of your AiM data equipment… whether you are new to racing or a seasoned professional there is always something new to learn. |
- LEDs: 1 system status
- CAN Connections: 2
- ECU Compatibility: + 1,000 industry leading ECUs
- Expansion CAN connections: GPS, Channel Expansions, Thermocouple Expansions, Lambda Controllers, SmartyCam HD
- Analogue inputs: 5 fully configurable, max 1,000 Hz each
- Digital inputs: 2 speed inputs, lap signal, coil RPM input
- Digital outputs: 1 (1Amp max)
- Accelerometer: Internal Three-axial + 5G + Three-axial Gyroscope
- Internal memory: 4GB
- Body: Anodised aluminium
- Weight: 330g
- Power consumption: 350 mA
AiM EVO4S Bike Data Logger Kit
- EVO4S with 1.3M GPS Module
- 75mm Potentiometer
- 150mm Potentiometer
- M10 0-100 bar Brake Pressure Sensor
- Motorcycle Bike Cable (whichever is chosen)
AiM EVO4S data logging kit provides you with all the help to improve your performance on the track or road.Key Features:
Connection Examples
- Weight: 330g
What's In The Box
