AiM Weld on Tab for Dash Bracket
SKU: UP-TAB
- Normal pris
- £3.00
- Normal pris
- Udsalgspris
- £3.00
- Pris per stk
- om
Weld on Tab
A simple weld on the chassis tab to facilitate dash and button mounts.
Key Features:
Weld on Tab
A simple weld on the chassis tab to facilitate our modular dash/button
mounts. 3mm Mild Steel Our Modular Steering Wheel Components are Stainless Steel (raw finish) interchangeable components to facilitate the mounting of displays/buttons/dash / lap timer/shift lights. |
Aim Technologies are committed to supplying, professional engineers with quality Motorsport products. Our cables and accessories are well-engineered and designed for demanding motorsport applications and the demands that racing puts on components. Which makes ours amongst the best in the marketplace today. |
Unlock your potential |
- 3mm mild steel
Technical Sheet |
Race Studio 3 |
Weld on Tab
Key Features:
Weld on Tab
- 3mm mild steel
Whats In The Box
Technical Sheet |
Race Studio 3 |
