Gå til produktinformation
1 af 1
AiM Taipan UC Bridge
SKU: C-UCB
Normal pris
£85.00
Normal pris
Udsalgspris
£85.00
The AiM Taipan UC Bridge is the connection between the CAN bus of the ECU and the USB port of your PC.
User licence Basic maps
The AiM UC Bridge is the connection between the CAN-Bus of the ECU and the port USB port of your PC.
It is available in two different licenses.
User License
The Taipan ECU comes with some basic maps that already give you better performances than the stock ones. Some highly professional tuners from around the globe offer specific maps that better fit your requirements, for example managing different exhaust tubes and two injector kits etc.
You will require the UC Bridge for the following two functions:
Transfering new and different maps to your ECU through the User License UC Bridge.
To receive the diagnostic information from the Taipan ECU.
Tuner License
With this license, the tuner can create maps, configurations and strategies designed for the rider's bike. The tuner can flash then directly on the ECU or send an e-mail to allow the rider to download and install them in the ECU.
Taipan ECU Connections - Optional Extra
AiM Taipan UC Bridge Technical Specifications and pinout
  • Connectors: n. 1 USB connection for PC
  • n. 1 JST 04R-JWPF-VSLE-S waterproof Connector for CAN Bus communication
  • Body: PA6 + 30% glass fiber
  • Dimensions: 103.5 x 45.3 x 18.1mm
  • Weight: 80g
  • 1 x Taipan UC Bridge
User License
Tuner License
  • Weight: 80g
Video
