Gå til produktinformation
1 af 1
Car Potentiometer Replacement Rose End Fitting
SKU: CASUS-POT-END-RJ
Normal pris
£8.50
Normal pris
Udsalgspris
£8.50
Replacement rose end joint fitting for the suspension potentiometer.
Replacement rose end fitting Spare or replacement parts
The Potentiometer rose joint fitting is a replacement part to fit the suspension potentiometer used to measure displacement between two points using a sensor.
Use as a replacement or spare part.
One Potentiometer Rose End Fitting Replacement Supplied.
  • Replacement Potentiometer Rose End Fitting
  • 1 x Rose End Fitting Potentiometer Replacement Fitting
