Gå til produktinformation
1 af 3
AiM MyChron 14mm Under Spark Plug Temperature Sensor Kart
SKU: S-T-CHT
Normal pris
£70.00
Normal pris
Udsalgspris
£70.00
The AiM cylinder head thermocouple sensor allows you to measure cylinder head temperature when the sensor is placed between the spark plug and cylinder head.
Measure cylinder head temperature  Thermocouple male fitting
Wide temperature range 2 pins
The AiM Cylinder Head 14mm thermocouple features a turn in its lower part for an easier installation/uninstallation; it has to fit between the spark plug and the cylinder head.
To keep the sensor in contact with the cylinder head, remove the washer from the plug when installing the thermocouple.
While running the thermocouple cable along with the chassis, keep it as far as possible from other lines (like RPM or lap receiver ones) to minimize cable interferences.
Please note: before screwing the spark plug cable back ensure that the sensor is firmly fixed to the cylinder head. While screwing it, minimize the thermocouple movements to avoid damages to the sensor.
Temperature range of 0-300°c
Sensor cable length 400mm
  • Temperature working range: 0-300°C
  • Cable sensor length: 400mm
  • Cable Type: Compensated
  • K Type thermocouple
  • AiM Cylinder Head 14mm Thermocouple Temperature Sensor
