Aim MXT 1.3 Strada IVA Compliant TFT Dash Display
SKU: MXT-IVA-CAN
- Normal pris
- £1,600.00
- Normal pris
- Udsalgspris
- £1,600.00
- Pris per stk
- om
An IVA Compliant Digital Dash Display
IVA compliant displays are essential for road legal racing vehicles in the UK, ensuring compliance with the Individual Vehicle Approval (IVA) standards. These digital dash displays offer compliance with road legality standards and connectivity with the vehicle's ECU to enhance performance.
Dash Key Features
Why Choose The Aim MXT 1.3 Strada IVA Compliant Dash Display
The MXT 1.3 has an integrated shift array, configurable multicolour alarms, drag and drop multi-page configuration, Wi-Fi and USB connectivity, GPS09 Module (optional), analogue and digital inputs, digital outputs, motorsport connectors, 4GB of internal memory, 1000Hz per channel sampling and support for over 1000 ECU connections.
The MXT 1.3 IVA dash samples data coming from your ECU, the GPS09 Module, 8 fully configurable analogue inputs, 6 digital inputs, predefined math channels and a second CAN. Performance and data acquired can also be incremented, adding up to eight expansion modules.
Freely Configurable Pages
You can define up to 8 custom pages, choosing among a selection of page styles, defining which data to be shown, their end of scale and measure units. Swapping between pages can be managed by pushing one or two pushbuttons.
Digital Display
The MXT 1.3 Strada has a high contrast, 10" TFT display. Visual quality is optimised by the ambient light sensor, which keeps the backlight at optimum brightness levels to ensure excellent readability and visibility.
Flexible Alarms & Custom Street Icons
The MXT 1.3 Strada features 6 configurable RGB alarm LEDs: you choose the conditions, and you choose the colours. Select a solid alarm or flashing one - and the flashing frequency, choose to have an accompanying text message, and set the alarm priorities. Furthermore, you can select the street icons you need from the wide list you will find in "Race Studio 3 - Icons Management" and set them up the way you prefer, or according to your needs. You will also be able to upload and set up your own customised icons.
Two Digital Outputs
The MXT 1.3 Strada features two digital outputs. The two digital outputs (Dout) are LOW SIDE type (switch to ground): they can be configured to be turned on/off depending on the value of the analogue or digital inputs. They permit to automatically run external systems, i.e. to switch on/off additional lights, to activate/de-activate a cooling fan or circulation pumps, etc. when a certain event happens.
Camera Inputs
Two analogue camera inputs are available to swap your display into a mirror camera through a pushbutton command or event management. The camera is sold separately.
Integrated Shift Light Array
Choose from a host of advanced multicoloured RGB shift light patterns that can be customised as you like, and for each unique gear when required.
Using the built-in CAN bus, you can add expansion modules to the MXT 1.3 Strada to increment the performance and the data acquired. Please note: These are only some of the items that can be added to our MXT 1.3 Strada.
- GPS09 Module: Thanks to the optional GPS09 Module and its Race Studio 3 software, you can immediately get lap times and all data needed for engine tuning as well as for improving driving technique.
- Channel Expansion: Allows you to add 4 0-5Volt analogue channels for pressure, temperature sensors and potentiometers. Two of these channels can be configured to receive digital inputs like wheel speed.
- TC Hub: An external expansion module that allows you to increase the number of thermocouples.
- LCU-One CAN: Wide band Lambda controller LCU-One, with Bosch LSU 4.9 probe, provides all Air/Fuel data and lambda value to perfectly tune the carburetion.
- Memory Module: The Memory Module is a small SD Card holder that can be connected via CAN bus to your MXT to record the data during your tests.
With Race Studio 3, you can also analyse all data recorded by MXT 1.3 Strada and download it to your PC: graphs, histograms and tables will help you study your performance, providing objective support to avoid mistakes and improve performances.
Dash Key Features
Digital Display
Two Digital Outputs
Camera Inputs
- Display: 10" TFT
- Contrast: 1,100:1
- Brightness: 800cd/m
- Ambient Light Sensor: Yes
- Alarm LEDs: 6 configurable RGB LEDs
- CAN Connections: 3
- Analogue Inputs: 8 fully configurable, max 500 Hz each
- Digital Inputs: 4-speed input, lap signal, coil RPM input
- Digital Outputs: 2 (1 A max)
- Second CAN: Yes
- Internal memory: 4GB
- Body: Anodised Aluminium
- Power Consumption: 450 mA
- Dimensions: 278 X 135 X 43.2mm
- Weight: 1,100g
What's In The Box
- MXT 1.3 IVA Dash Display
- USB Cable
- 14 Pin Standard harness
- Aim Sticker
